Author Topic: Location of tach wire through firewall  (Read 3401 times)
Offline challenger_73
« on: January 17, 2016 - 02:15:23 PM »
Does anyone have a picture of where the tach wire comes throught the firewall and the grommet that is used for it?
challenger_73
Offline FY1Cuda
Re: Location of tach wire through firewall
« Reply #1 on: January 17, 2016 - 02:52:54 PM »
On a '70 the tach wire goes through the bulkhead connector (spot #20). Just looked at a '73 wiring diagram... Same thing.
http://www.mymopar.com/downloads/1973/73ChallengerA.JPG
« Last Edit: January 17, 2016 - 02:56:14 PM by FY1Cuda »
« Reply #2 on: January 17, 2016 - 03:47:49 PM »
Not on a Challenger. Separate wire with it's own hole and grommet.
Sorry OP, don't know exactly where it is supposed to go. I just drilled a hole where I wanted to put it.
« Reply #3 on: January 18, 2016 - 09:34:09 AM »
Thanks guys!  I  think that is what i will do.  Thanks for the help.
challenger_73
Offline Grec
« Reply #4 on: January 18, 2016 - 10:09:50 AM »
Hold on, bud.
There's a specific place for it. (there's a dimple where the hole goes.)
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline Grec
« Reply #5 on: January 18, 2016 - 10:15:59 AM »
Actually... now that I think about it, I may have tach wire and clutch safety switch mixed up in my firewall-hole-drilling recollection...
The factory tach wire setup plugs into the firewall bulkhead... and then connects to the neg on coil. Gray w/black stripe wire.
There's different ones depending on BB or SB... (length of lead)
http://www.classicindustries.com/product/1970/mopar/parts/me8112.html
« Last Edit: January 18, 2016 - 10:20:41 AM by Grec »
- 440 Six Pack
Offline roadman5312
« Reply #6 on: January 18, 2016 - 10:18:35 AM »
    Firewall.
Offline roadman5312
« Reply #7 on: January 18, 2016 - 10:19:47 AM »
reverse light has it's own hole, tach wire in bulkhead.
« Reply #8 on: January 18, 2016 - 12:33:44 PM »
 :iagree: but the position may change n different years
Offline YellowThumper
  • I left the snow for this?
« Reply #9 on: January 19, 2016 - 06:25:26 PM »
Checked and it is located in the bulkhead.
I will try and look on my 74 tonight and report back what I have.
If not tonight tomorrow then.
« Last Edit: January 19, 2016 - 08:36:06 PM by YellowThumper »
Offline lulurocks
« Reply #10 on: January 19, 2016 - 08:53:44 PM »
My tach Grey wire w black tracer  went thru firewall in its own grommet  like the service manual shows .
Mines a 73 rallye 340 auto car.  I traced it in the harness the best i could and it went to the grommet .
I could be wrong  :2cents:
My glorious hand model pic shows where the wire came thru , see below
« Last Edit: January 19, 2016 - 09:02:05 PM by lulurocks »
« Reply #11 on: January 19, 2016 - 09:38:19 PM »
'73 is a separate wire with it's own grommet. Any other year, I have no comment.  :bigsmile:
« Reply #12 on: January 19, 2016 - 11:21:45 PM »
Well my 74 ain't got dat hole... :clueless:
« Reply #13 on: January 20, 2016 - 02:37:06 PM »
Uh oh! Too late! I already drilled the holes. I drilled them in the right place and installed the grommets already. You really can't see them to well anyway as they are behind the brake booster. Thanks for your help everyone.
challenger_73
