Here's a discussion I found. The answer seems to be you are a little slower due to having to overcome rotational inertia of the larger wheel, not increased friction due to more rubber on the road, as was initially claimed. I noticed on the Tire Rack website that the larger the wheel diameter, the more the wheel weighed, in general. So basically, if you go from 15s to 17s or 18s, etc, you will lose some quickness.
My friend and I both have a 98 GS400 and we constantly race one another. We both do not have any mod's and are running completely stock except for his rims. Here's where it gets interesting. He recently got 18'' rims with Toyo T1. I am riding on the stock 16's with the Goodyear eagle garbage. Before he went to 18's he was also on stock 16's and we use to be neck and neck all the way to 80mph which was expected. Since he went to 18's, my car launches a bit quicker and I am almost a full car length ahead of him to 80mph. We only race to 80 mph, nothing over that. We did this several times and it was the same result every time with my car on 16's ahead by a full car length. We even switched cars and he pulled ahead of me in my own car ....this was to eliminate the driver skill. His car definitely handles much better, but its the 0-60 sprint time at a traffic light which really matters to most of us.
The conclusion we came too is this: With his wider tires, he has almost 2'' of extra traction per tire multiply it by 4 and you get 8'' of extra traction and more friction. This obviously helps make a big difference in the handling department but actually slows the car down a bit from 0-80 mph. Technically, wider tires have more friction, and more power is required. But since the rear wheel HP is the same in both cars, his wider tires actually slows down the car. The only reason to go to 18's or higher in my opinion is if your car's HP increases so the tires can better handle the extra power or better handeling or purely for the looks. His car also rides much harsher which was expected. I think a good compromise would be to the optional stock 17 which I am planning on going to in a couple of months with Yoko dB's. My stock 16's are just too floaty especially at speeds over 80mph.
We are both surprised and shocked at these results. He is trying to convince me to swap my stock 16 with his 18's and race again. He is the kind of person that just doesnt take no for an answer. I probalby will end up doing this this weekend and will post a followup w/results on monday providing the weather is good.
__________________
Current cars:
2003 Dinan S2 BMW X5 sport/navi, 2001 Mercedes S430 sport/navi, 2006 Odyssey EX-L res/navi, 2004 Maxima SE, 2008 Accord V6/Navi
Previous cars:
Modified spectra blue GS400-Sold, Lexus ES300/navi-Sold
DrewGS4 is offline Reply With Quote
Old 02-14-02, 08:52 AM #2
mooretorque
Lexus Champion
Trader Score: (0)
Talking
Decreased acceleration due to greater rotational inertia of a heavier wheel and tire unit, not increased friction. However, assuming no change in circumference, top speed remains the same, just takes a little longer to get to.
__________________
2011 IS-F, Mercury Metallic/black leather/Alcantara,B option package.
2008 GX470, white/tan (HER car)
1997 Volvo 850R, black/black (for the older son)
Lest we forget: 2001 GS430,2004 RX330,1999 RX300, 1994 ES300,1993 SC300 5MT, 1991 SC400
Lexus owner since 1991
mooretorque is offline Reply With Quote
Old 02-14-02, 08:53 AM #3
DrRick
Lexus Champion
Trader Score: (0)
DrRick's Avatar
_mav_rick 1mavrick
Send a message via AIM to DrRick Send a message via Yahoo to DrRick
Default
well depending on the 18's, he has probably increased the weight over the 16 inchers. this increases unsprung weight and inertia at the rear wheels. with the increase in inertia (an object at rest tends to stay at rest) it will take more power to get them moving. and since there has been no such increase, ie mods, he will be slower of the line. that is why you see guys here that have 20s and such that are heavy complain that there car isnt as fast as it used to be. however, there really shouldnt be too much difference once the car is moving. thus ends the physics lesson for today boys and girls..........Dr. Crosthwaite at UNCC would be proud.
Read more:
http://www.clublexus.com/forums/gs-2nd-gen-1998-2005/37438-can-larger-rims-and-wider-tires-can-slow-down-your-car.html#ixzz3xlVwES18
