I use Hughes hold downs, I also place at least 1 shim between the rocker & the hold down & 1 shim between the rocker & the spring.... Some guys change the springs for solid spacers.... I have lighter springs I was planning to use but a few old racers tell me the heavy springs are better...
You need to check the alignment of the hardened pad over the valve, often the rockers need a quick modification in a lathe to properly center the pad... I usually cut .050-.065 off the side of the rocker that contacts the hold down, that allows you to set the contact with shims....
