Author Topic: leaf springs  (Read 3086 times)
Offline automate33
leaf springs
« on: January 20, 2016 - 09:46:37 AM »
Hi guys,
rear of my challenger  is too hight.
Do you know how is possible to down rear?
I don't know if the leaf spring is correct..
How can i check?
 :working:
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: leaf springs
« Reply #1 on: January 20, 2016 - 09:56:35 AM »
When they were made with stock springs the rear was a little lower than the front.  I actually like the rear higher than stock, so to me it looks good.  One way to check what springs you have is to count the the leafs on each side.  You may have SS springs or the PO may have added a spring or re-arched them and added a few inches.  To lower the car you can either have a leaf removed, de-arch the springs, or install a spacer.
Offline automate33
Re: leaf springs
« Reply #2 on: January 20, 2016 - 10:03:26 AM »
i want to down rear because at 80mph i have vibration in the rear transmission
Offline dfrazz
Re: leaf springs
« Reply #3 on: January 20, 2016 - 10:47:07 AM »
Just lowering the rear may or may not fix your problem.  Your driveshaft may need to be balanced, you need to adjust the angle, or it could be a loose trans cross member, or something else.
Offline cudabob496
Re: leaf springs
« Reply #4 on: January 20, 2016 - 04:52:54 PM »
places will recurve your leak Springs.
My stock new ESPO springs are great, and just the right height
2011 Kawasaki Z1000
Offline msbaugh
Re: leaf springs
« Reply #5 on: January 20, 2016 - 10:33:47 PM »
Do you have a picture of yours from the side?
Offline TelisSE440
Re: leaf springs
« Reply #6 on: January 24, 2016 - 03:20:05 PM »
To me is the perfect height, but as Dfrazz says I like the rear raised, in the Challengers.
Re: leaf springs
« Reply #7 on: January 24, 2016 - 06:14:00 PM »
To me it looks like a raised truck rear. It needs to be lower, IMO. Will improve handling and stability.  :2cents:
The rear was not lower than the front from the factory, it appeared that way because the rear tires were supposed to be tucked up inside the rear wheel wells a bit while the fronts were fully exposed. Made it appear that the rear was sagging.
Offline dfrazz
Re: leaf springs
« Reply #8 on: January 24, 2016 - 08:55:48 PM »
You may be right dodj, but to me it looks lower, just look at the front and rear bumpers below.  Maybe its the way the rear end droops off, unlike the higher rear on the Cuda.
Offline anlauto
Re: leaf springs
« Reply #9 on: January 24, 2016 - 09:02:06 PM »
I think the height looks perfect :2cents:
Offline Skunkworks Challenger
  • Mopars forever!
Re: leaf springs
« Reply #10 on: January 24, 2016 - 09:15:26 PM »
To determine if front or rear is heigher measure the rockers front and rear.  My Challenger with new ESPO stock height springs measures 1/4 inch higher in the rear, from garage floor, and is perfect for my tastes.
The Brewmaster
Offline TelisSE440
Re: leaf springs
« Reply #11 on: January 25, 2016 - 04:25:15 PM »
The only thing I see in my Challenger is the hippie line which is not parallel to the ground, it goes upward. The black Challenger has it perfectly parallel to the ground.
Offline CUDA JAS
  • vroooooom!
Re: leaf springs
« Reply #12 on: January 25, 2016 - 05:07:54 PM »
I agree, that should be enough....I have measure mine and the rear is slightly higher then the front...but I swear it still looks like the rear is lower than the front.
74 'cuda 360/727
Just call me a gearhead!
Offline jimynick
Re: leaf springs
« Reply #13 on: January 25, 2016 - 10:17:12 PM »
Like many here, I like the way yours sits, but if you HAVE to have it lower, here's the best way to do it. Drive down to the beer store and buy/load 6 24's in the trunk, then go down to the nearest college and persuade 2 cuteys to help you drink the beer, load them in, then go to your best buddy's place and show him what's in the Challenger. By the time you get him and all your other gear in it, you'll be right where you want it to be. If it's still a wee bit off, just drink some of the beer and toss the empties to fine tune it. There, wasn't that easy- and fun, too?!  :cheers:
Offline blown motor
Re: leaf springs
« Reply #14 on: January 25, 2016 - 10:41:10 PM »
Suspension tuning 101 by Ian.  :lol:
