it's interesting and has some obvious uses for sure, but I wonder about the long term viability for iron based metals. aluminum won't rust, so laser etching a pattern that repels water makes sense. but laser etching any iron based metal will still lead to corrosion due to moisture in the air that is at the molecular level and the laser etchings won't effect at all, I would think that it would actually open up the material to more surface area for the rust to take hold and penetrate faster.
personally, this is the stuff I'm excited to try out
http://www.nanodiamondshield.com/ Nano Diamond Shield is an Amazing New Product that provides your car with a Super Hydrophobic Non-Wax sealant that is Guaranteed For One Year. Each can contains Tens-of-Billions of ultra-hard nano-glass particles that will bond to the surface of your vehicle. Here are a few reasons why Nano Diamond Shield is becoming so popular:
Takes 20 minutes to apply
Guaranteed for 1 year
Replaces many other products
Super Hydrophobic (Water Beads on Surface For One Year)
Will not harm any surface
Safely apply Nano Diamond Shield to all of these surfaces:
Paint
Hardens the surface to 4-H to prevent swirl marks
Leaves paint glossy and shiny for 12-months
Water beads up for 12-months
Extremely resistant to UV, Acid Rain, Chemicals, Bugs, Tree Sap, etc..
Wheels
Brake dust will just rinse off with water
No need for expensive wheel cleaners
Glass
Water will bead-up and run-off for 12-months
Will not damage your wipers like other products
Trim
Provides the highest level of UV protection to eliminate fading
Amazon reviews help too
http://www.amazon.com/Crystal-View-Chemicals-Diamond-Shield/dp/B0058UJJHC
