Author Topic: LA 360 differences?  (Read 639 times)
Offline Swedee
    • www.My72Challenger.com
LA 360 differences?
« on: January 22, 2016 - 02:25:07 PM »
Hi
Did some googling today on LA 360's but couldn't find any obvious reason why they differ quite a lot in terms of HP's inbetween 1971-1989.
In 1971 255 HP's and from there it went downhill...
Could some explain what happened (as I cannot find any obvious reason)?
Thanks!
Check out my blog at www.my72challenger.com
Re: LA 360 differences?
« Reply #1 on: January 22, 2016 - 07:23:30 PM »
They made a 360 in '71?!?
I thought they started in '74?
« Reply #2 on: January 22, 2016 - 11:54:51 PM »
yes 71 360s were in C bodys & trucks .
 Partially loss of compression not that even a 71 had high compression , gross rating down tot net ratings , cam changes & other adds on for emissions all killed off power
Offline Mopar Monster
« Reply #3 on: January 23, 2016 - 02:30:41 AM »
Do the roller camshaft & rockers make the difference in gains?  I did some inquiries about stroking the 360 block & I learned that some late model 360 blocks use different heads & camshafts than later years.
There were other differences in the webbing & other features.  I ended up finding an '83 360 long block with engine stand for $60.00.  It's not the roller cam block I wanted but the price was right. :cooldancing:
« Reply #4 on: January 23, 2016 - 07:14:49 AM »
the roller cams are better for both emissions & power
