Author Topic: logical plan of attack for rebuild  (Read 1905 times)
Offline DadsCuda
« on: January 23, 2016 - 05:46:01 AM »
i'm not sure if this is where this question should go, but it's a general plan type of question.
my 67 barracuda is still up on jack stands. it's winter and a storm's approaching the east coast today.
i'm basically trying to get my ducks in a row so i can get to work on actually putting parts back on this thing, rather than just taking things off.
so my question:
should i be thinking about my exhaust system while my rear end is all in bits in my shed? my hope is to get my parts to reassemble the rear drums, leaf springs, shocks, axle once the weather turns warm again, so i'm making my parts lists and trying to find the best deals and options there.
however...should i be considering the exhaust while the rear is all empty? does it make more sense to get the exhaust in and then mess with the axle and springs? or vice versa?
(full disclosure: i literally just remembered the exhaust because my mind has been on my front disc conversion...i need to find my focus!)
Offline dakota
Re: logical plan of attack for rebuild
« Reply #1 on: January 23, 2016 - 06:42:59 AM »
It will depend a bit on what you want to do with the exhaust.   If you're planning to replace everything anyways and have the money to do it, replacing the exhaust will be easier to deal with while the back end is out.  That said, the exhaust can be changed out even after the car is fully assembled because it can go back in small pieces that are clamped or welded together, so it's not something you have to do right now if you're trying to conserve $ where you can.   I always laugh at myself when I go back to when I started my project because I was only going to change out a cracked dash pad.   One thing led to another and now my car is completely gutted.  It should work out in the end, but I've been telling my son repeatedly that he should limit the tear downs on his project car to just a couple of systems at a time or he will end with parts everywhere.
One thing I would suggest you consider doing while the back end is out is dropping the gas tank.   Between the dry rot on the rubber fuel line, a level float that had a hole in it such that it was more of "sink", cracks in the rubber grommet where the fill pipe goes into the tank, and a pile of rust scale sitting on the bottom of the tank just waiting to plug any and all fuel filters, everything needed to be replaced.   I bought the replacement stuff as a kit from Roseville and would readily recommend it.  Post another note if you have any questions on handling any gas fumes or leftover gas.
Offline DadsCuda
« Reply #2 on: January 23, 2016 - 07:33:43 AM »
Ah! Thanks! I have the manifolds and will need to get everything new from that point on back. But if I can wait til the back end is replaced (that is, the axle, springs, gas tank, etc) then I think I'll figure that out later, so I can concentrate on one thing for now.
Thanks for the advice on the gas tank, too. Luckily we dropped & emptied that when my brother was still able to help me & could dispose of the gas where he was working. 'There should only be a few drops of gas in there.'...12 gallons later...'do you have another bucket??' Life is full of funny stories😳
That said...Is there a way to save that $80 to salvage the gas tank? Is there a way to clean it out? Or is it not worth the risk of bits that could get left inside?
Offline dakota
« Reply #3 on: January 23, 2016 - 08:30:05 AM »
There are products available that coat/seal the inside of a used gas tank, but there are also lots of stories about the coatings coming off and plugging up the fuel system.   I believe you will be much better off with a new tank.
Offline 1 Wild R/T
« Reply #4 on: January 23, 2016 - 11:40:38 AM »
Get a new tank, you won't regret it....
Exhaust is best done with the car on a wheel lift after the axle is back in, that way you can see how it clears everything.... If your running a rear sway bar have it on, have the shocks on, have the parking brake cables in place......
Offline rUNCHARGER
« Reply #5 on: January 23, 2016 - 03:40:20 PM »
Logically: My priority is having the car able to be rolled around so I concentrate on the suspension and brakes first, however mounting the new hard brake lines and body fuel line should be done first. Don't screw around, buy a new gas tank and put in new fuel lines as well as all new brake lines, no question. As stated the exhaust can easily go in after the suspension and you can make sure it doesn't rub at that time.
Sheldon
« Reply #6 on: January 27, 2016 - 08:29:04 PM »
I always assembled the fuel & brake lines , then rear suspension , gas tank , then the front suspension with engine & K frame
Offline DadsCuda
« Reply #7 on: January 28, 2016 - 03:49:33 AM »
Great! This is all very helpful!! I'm pulling the trigger & ordering my parts needed to get the rear end all put back together so I can get ready to work on the front & engine when that's done!
This is where I start to really get nervous...I like knowing y'all are here!! :)
