As luck would have it, I ran into an old-school mechanic buddy of mine yesterday while out and about.
I told him about my starting issue, but that otherwise the car was running great. His 1st response was "It's probably the fuel, dude. The gas that was around when this car, and those carbs, was designed is totally different than the crap we're forced to run today."
Which is what a couple of you have suggested.
His fix for the starting issue? "Don't pump it, but give it about 1/4 - 1/3 throttle as you're starting it." Sure enough. It starts up MUCH better this way. Still not as crisp as that initial cold start, but it definitely isn't the embarrassing display it has been. Lol
Also, find some better gas if possible.
As for my CR, I'm running dished pistons w/ those 915s, but it's definitely on the edge of what you should be running on pump gas. I think I need to track down some higher octane
