Author Topic: help needed diffrent place to mount rotisserie  (Read 1270 times)
Offline anthonywr450f
« on: February 01, 2016 - 07:50:58 PM »
hi all am needing to get my new build (dodge challenger)fully blasted to let the work begin only problem is were most mount rotisserie in rear on bumper mounts carnt really use as the hack that had car before me has not welded them to floors or any were and they need replaceing so don't want to lift of them incase they bend as badly rusted
is there any other points that some 1 has used or seen used instead them ?
any info would be appreciated cheers
Offline 70chall440
Re: help needed diffrent place to mount rotisserie
« Reply #1 on: February 01, 2016 - 11:51:00 PM »
if you think it will bend by putting it on a rotisserie, it may be having issues sitting on the suspension as well. Either way, you need to weld in some cross braces, then after blasting check the frame for straightness. Just get some tubing, rods, etc and brace the crap out of the car before hooking it up. You can cut it all out later.
Current Mopar
Past Mopars
Offline rhamson
« Reply #2 on: February 02, 2016 - 08:20:07 AM »
I would first get the frame right before going on to the blasting. Set the car on jack stands and repair or replace what is needed to make it right before blasting. Then set it up on the rotisserie. Blasting the things that don't need blasting is a waste of time and materials.
Offline 70chall440
« Reply #3 on: February 02, 2016 - 11:56:51 AM »
Current Mopar
Past Mopars
« Reply #4 on: February 02, 2016 - 05:30:12 PM »
Ok thanks yea thinking might plate frame rails and reinforce like u said to get blasted so I no what I got to work with and if there is more damage then I thought can fix at same time
Cheers
