Author Topic: Shaker cable binds only when it's curved  (Read 1403 times)
« on: February 01, 2016 - 11:39:31 PM »
Just got around to putting the hot & cold air door on in the shaker.
With the Bubble off upside down and the cable straight, it works fine.
But as soon as I curve it like it's supposed to be, it's too stiff to operate the doors.
I bought it from DCS. Any suggestions?
Offline 70chall440
Re: Shaker cable binds only when it's curved
« Reply #1 on: February 02, 2016 - 12:02:27 AM »
Have you tried to lub it? I cannot say I have a lot of experience with shaker cables, but I do with heater cables and I have run into this with them. Sometimes (especially when new) they seem to drag against the inner lining. I use white lithium grease and have even used a motorcycle cable lubrication tool (it pierces the outer housing allowing you to squirt lub into the cable) to get them working.
good luck.
Current Mopar
Past Mopars
« Reply #2 on: February 02, 2016 - 12:07:05 AM »
Graphite spray made no difference.
Offline 70chall440
« Reply #3 on: February 02, 2016 - 12:11:29 AM »
Hmmm has to be dragging somewhere inside it in the liner. Maybe a liquid lubricant would work better.
Current Mopar
Past Mopars
« Reply #4 on: February 02, 2016 - 12:36:50 AM »
Where can I get a motorcycle lubricating tool for the cable?
Or should I send it back?
« Reply #5 on: February 02, 2016 - 08:51:48 AM »
T alk to the supplier
Offline 70chall440
« Reply #6 on: February 02, 2016 - 11:23:49 AM »
Agree, since it is new I would talk to the people you got it from.
Any motorcycle shop will have the lubrication tool.
Current Mopar
Past Mopars
Offline Racer57
« Reply #7 on: February 02, 2016 - 10:01:23 PM »
"A tool" !?!?!?    Oh my god people. Cut a piece of construction paper or thin plastic from a jug of some sort and twist it into a funnel. Fasten it with a screw driver clamp. Pour some of your favorite lube into it and let it hand over night. :D
Btw, I've lubed mine enough and even used an air hose hoping it might do some good and mine still binds. I think its just a bad design with too many hinges and cables.
« Last Edit: February 02, 2016 - 10:04:13 PM by Racer57 »
Offline onebadfish
« Reply #8 on: February 02, 2016 - 10:06:09 PM »
Mine bind too...
