Author Topic: 1970 440 Challenger Trans Swap  (Read 2382 times)
Offline jghqaltga5926
  • Newbie
« on: February 02, 2016 - 04:22:04 PM »
Hello everyone! I'm new to the site and hope I can find some help. I've got a 1970 challenger with the 440 with the A727 auto. I'm looking at putting 3.91s in it but after a friend of mine ran the numbers, I'm not liking the idea of 3500 rpm at 70mph. Looking for suggestions and tips on a possible transmission swap. Right now I'm thinking either the A518 or A833 just don't know how difficult it would be to go from auto to manual? Also, I'm unsure as far as how easily there options will play with 440 and E body. Any and all help would be greatly appreciated.
Thanks,
Matt
Offline 70chall440
Re: 1970 440 Challenger Trans Swap
« Reply #1 on: February 02, 2016 - 04:25:08 PM »
it isn't that hard to go from AT to MT, especially with the kits available from Brewers or Passion. Definitely takes some fabrication to a small degree but nothing that is crazy.
Current Mopar
Past Mopars
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2 on: February 02, 2016 - 04:39:51 PM »
First of all, welcome for CO to one of the best sites for e-bodies.  A LOT of knowledge and friendly guys to help here.
You need to ask yourself do you want an auto or manual? Huge difference and the cost of just all the parts are about $4500-5000 for an A-833 4 spd depending on what you want.  Contact Brewers for more information  http://www.brewersperformance.com/
If you want to stick with the 727, you can switch out your gears to 3.55 or 3.23 (more highway but less off the line).  Least expensive choice and will lower your RPM.
Another alternative is stay with your current set up and add a Gear Vendors overdrive.  https://www.gearvendors.com/cgi-bin/shop/search.cgi?1.+MANUFACTURER=DODGE&2.+VEHICLE+TYPE=CAR&3.+MODEL=CHALLENGER&4.+YEAR=1970&5.+TYPE=STOCK&6.+FUEL+TYPE=GAS&7.+WHEEL+DRIVE=REAR+WHEEL+DRIVE&8.+TRANSMISSION+TYPE=AUTOMATIC&9.+TRANSMISSION+MODEL=3-SPEED+727+18%22+TAILHOUSING&submit.x=16&submit.y=7&submit=GO   https://www.youtube.com/watch?v=SywsCGnoXOU
Offline Katfish
  • 70 Challenger
« Reply #3 on: February 02, 2016 - 05:53:13 PM »
Best thing I ever did, car is so much more fun to drive
http://www.cuda-challenger.com/cc/index.php?topic=84774.0
Offline anlauto
« Reply #4 on: February 02, 2016 - 05:55:58 PM »
I would go with 4:10's and a gear vendors overdrive :burnout:
« Reply #5 on: February 02, 2016 - 08:53:27 PM »
I would go manual with 833 OD or Passon 855 .
 518 is a great choice if you are OK with auto
« Last Edit: February 04, 2016 - 09:23:28 PM by Chryco Psycho »
Offline CudaHead
« Reply #6 on: February 04, 2016 - 04:44:41 PM »
I'm doing something similar. I'm considering this:
http://americanpowertrain.com/i-22339177-mopar-automatic-overdrive-kit-b-and-e-body.html
The only problem I see with it is the lack of a factory looking console shifter that allows all 4 gears to be select manually.
It also does not require a computer box, nice.
I was also reading the latest Mopar Muscle and they did a story on new stuff from SEMA. They mentioned a new one from Gear Venders that is 10 inches shorter than the current one they sell.
I have not seen anything on their website yet but I'm waiting until I hear more about it.
CudaHad
Offline CUDA JAS
  • vroooooom!
« Reply #7 on: February 05, 2016 - 10:46:40 AM »
No 4:10s with the A-518???
That sounds like fun to me!!
74 'cuda 360/727
Just call me a gearhead!
