Author Topic: Tremec TKO500 / 440cid pilot bearing  (Read 2209 times)
Offline 440Mag
« on: February 03, 2016 - 10:16:15 AM »
Hi!
I got a problem;
I need pilot bearing for my 440/tko500 swap. Bearing OD is 1.7805 and id .672
From where I can get that?
JS23V
Finland
Offline anlauto
Re: Tremec TKO500 / 440cid pilot bearing
« Reply #1 on: February 03, 2016 - 10:18:20 AM »
Have you tried American Powertrain ?
Offline DocMel
« Reply #2 on: February 03, 2016 - 02:54:31 PM »
Should have come with the kit, mine did.
Offline 440Mag
« Reply #3 on: February 03, 2016 - 03:08:23 PM »
Yep, but it went with my old engine/crank to new owner.
JS23V
Finland
Offline DocMel
« Reply #4 on: February 06, 2016 - 11:35:49 AM »
Ok, got ya.  I would try any vendor that sells the T500.   Im wondering if the pilot bearing on a T500 is the same size as a OEM, 440 4 speed tranny pilot bearing.   Anyone?
Offline moprr
« Reply #5 on: February 10, 2016 - 11:45:07 AM »
I believe member bigblue used to have these bearings you can check with him.
Offline bigblue73
« Reply #6 on: February 17, 2016 - 01:03:09 PM »
Do you need the entire thing or just replace the roller pilot bearing.  I have these in stock.  feel free to PM me.  $50.00 shipped in the U.S.
What are the numbers on the side of your Tremec.  I need to be sure its a Ford version or the Chevrolet.  The Mopar Conversions use the Ford based unit because of the input shaft length.
« Last Edit: February 17, 2016 - 01:06:34 PM by bigblue73 »
Offline 440Mag
« Reply #7 on: February 18, 2016 - 05:39:09 PM »
Thanks, but it might be difficult, because I'm from Finland, Europe.
I bought Ford roller bearing, and I took it to machine shop. They make adapter for that mopar crank.
JS23V
Finland
Offline bigblue73
« Reply #8 on: February 22, 2016 - 04:31:39 PM »
You got it.  Machine the O.D. of the bearing to 1.8145 inches (46.083mm).  I ship worldwide if you still can't get it.  Cheers and good luck!
Offline 440Mag
« Reply #9 on: March 04, 2016 - 02:41:15 PM »
Thanks for that OD diameter info! I machined it and now its correct  :cheers:
Hope that tko500 can handle my 500ci...
JS23V
Finland
