Author Topic: Proform Carburetor mounting  (Read 1285 times)
Offline Challenger in NC
« on: February 04, 2016 - 12:42:04 PM »
I just received my Proform 850 carb. The only documentation that came with it was a card that listed jet sizes. Does anyone know what type of:
1) bracket, springs, throttle cable, and throttle stop would work well
2) any suggestion for carb fuel lines and fittings kit? Any other components I may be forgetting? I believe I already have a fuel filter and pressure gauge.
This application would be for a 440 with a holley 4 barrel intake and 4 speed trans.
Thanks,
Chris
« Last Edit: February 04, 2016 - 08:56:50 PM by Challenger in NC »
Offline Strawdawg
    • Vortex Buicks
Re: Proform Carburetor mounting
« Reply #1 on: February 04, 2016 - 02:30:30 PM »
If you have a TF tranny, then you will need the Holley 20-7 adapter.
Summit or Jegs will have it plus you can buy the dual bowl inlet plumbing there.  Several choices of varying price ranges for that.
« Reply #2 on: February 04, 2016 - 02:36:38 PM »
Thanks, been scanning Summit for the inlet fuel lines, lots to choose from. I should have mentioned that trans is manual.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: February 04, 2016 - 02:41:12 PM »
It will also depend on the type of intake. High rise one like mine required a different linkage setup which I bought here:
http://www.ebay.com/itm/Mopar-Big-Block-High-Rise-Intake-Manifold-Throttle-Cable-Bracket-Mounting-Kit-/222011771315?hash=item33b0eec9b3:g:dXEAAMXQfvlSmVSo&vxp=mtr
This guy also makes a low rise one as well. But if you are into stock looking there are several on ebay as well.
« Reply #4 on: February 04, 2016 - 02:58:53 PM »
A few members have suggested the Holley Street dominator, so I may go with that, which I believe is close to stock height.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #5 on: February 04, 2016 - 06:05:25 PM »
You can also call Proform, really nice guys to deal with - https://www.proformparts.com/info-exec/display/contact_us
« Reply #6 on: February 04, 2016 - 09:22:17 PM »
Holley makes an adapter for the lever to correct the leverage 20-7 .
 Stock throttle cable should work or just make an extender from a chev valve cover load spreader .
 Mancini has a throttle cable bracket that will work with a high rise intake .
 There are 2 different fuel line lengths for carbs with or without secondary metering block , you want the longer or adjustable one .
« Reply #7 on: February 04, 2016 - 09:44:49 PM »
Thanks all for the info, this will help.
