Resto Mod 1973 Barracuda round 2
Author Topic: Resto Mod 1973 Barracuda round 2  (Read 47671 times)
Offline redo1973
Re: Resto Mod 1973 Barracuda round 2
« Reply #90 on: July 06, 2016 - 08:43:51 PM »
Thanks folks.  It finally feels like progress. I’m still trying to line-up a body/paint guy and have some panel work to be done but I’m specifically looking to decide what to do on the fenders and driver door.  I’d appreciate feedback on whether to repair or replace, keeping in mind that this is not a high-end restoration.
The driver door has minor dings like from a parking lot and the frame of the door is solid.
The passenger fender has deep pits underneath near the headlight can.  I’m concerned that the fender can’t be repaired fully and will eventually rust through.
The driver fender has a through hole with deeply pitted rust and through hole on the fender brace.  I know that there is a patch panel for this but is it worth it when paying for the repair versus a complete new fender?
Offline turbostang7
« Reply #91 on: July 06, 2016 - 10:04:34 PM »
Looks repairable to me, I would keep all the original steel you can. They sell patches for the lower part of the fender.
1970 Barracuda project in the making!
Offline redo1973
« Reply #92 on: July 07, 2016 - 08:32:28 PM »
Thanks.  I'm thinking the same but compelled to compare costs.
Offline 70chall440
« Reply #93 on: July 08, 2016 - 11:29:58 AM »
New panels have an attraction if you can afford them, however I will say up front that while the steel will be new, it will never fit as well as what you have. I replaced complete rear quarters, 1 door skin and both fenders because I had no choice. I spent a lot of time making it fit and if you are going to pay someone to fit the panels and paint the car, it could be more expensive than repairing what you have. that said, good research and thinking it through it worth the time to determine the best course of action.
Current Mopar
Past Mopars
Offline redo1973
« Reply #94 on: July 08, 2016 - 09:19:21 PM »
Thanks.  I remember your struggles with the fender.  I'm thinking that I'll stick with the original.  I won't be tackling it but the area of most concern is that passenger front contour with the pitted rust. I suspect an expert can fabricate the patch that better than I.  I'll keep you guys posted. Thanks for the input.
Offline usraptr
« Reply #95 on: July 09, 2016 - 08:50:33 PM »
I'm not a body man, but I would think a good body man could fix those issues.  I know mine could as I've seen him work miracles on mine and other cars.  I agree you want to stay with the original panels if possible.  Good luck.
(Edited 8-1-17)
Offline redo1973
« Reply #96 on: August 11, 2016 - 08:31:33 PM »
July 2016
Okay I finally finished cleaning the undercoating from the fenders, header and front spoiler.  Good news in that the damage is limited to the fender braces of both fenders.  That passenger fender pitting was resolved with a wire brush and the urethane primer.  I’ve also coordinated with a body guy to bring this into final paint so I’m going to roll with the original metal.
Offline redo1973
« Reply #97 on: October 24, 2016 - 07:06:15 PM »
I've sent the rolling chassis for final metal prep and bodywork/paint.  I have a question on how folks deal with the nomenclature plate on the driver door.  How do your restore, protect or replace this plate?
Offline 70chall440
« Reply #98 on: October 26, 2016 - 08:20:23 PM »
They are reproduced now (I believe ECS does it), however I have always taped them off carefully.
Current Mopar
Past Mopars
Offline rUNCHARGER
« Reply #99 on: October 26, 2016 - 08:57:34 PM »
Take a photo of the VIN decal and send it to ECS, They will make one that matches perfectly for you.
Sheldon
Offline EB3-GranCoupe
  • BP23 U0B
« Reply #100 on: October 27, 2016 - 08:03:15 PM »
Quote
and a photocopy of your title.
had mine done for my GC. turned out beautiful!
Offline redo1973
« Reply #101 on: October 27, 2016 - 10:00:28 PM »
Thanks folks.  I spoke with Tom at ECS.  Great guy.  I sent a picture into him and the sticker is on its way.
Offline redo1973
« Reply #102 on: November 10, 2016 - 09:49:36 PM »
I am having difficulties doing the final alignment of the quarters to the taillight panel and filler piecs.  I'm wondering if I installed the taillight panel correctly.  I replaced it like the original but I had not installed the trunk pan.  It seems strange that there would be a seam on the outside of the car.  Can anyone confirm that the taillight panel sits inside the trunk pan lip extension?
Offline 73_Cuda_4_Me
« Reply #103 on: November 17, 2016 - 08:14:01 AM »
My trunk pan lip is on the outside of the tail panel, with seam sealer covering the lip. Mine is also eaten away from the moisture/salt that stays under the lip of the trunk pan. I'll be replacing the trunk pan lip eventually.
I painted tail panel 1 year ago and got a couple of pix, so you can see where mine is eaten away.
Previous owner's home made tips are finally replaced with correct ones on new 2 1/2" exhaust installed this summer.
« Last Edit: November 17, 2016 - 08:48:39 AM by 73_Cuda_4_Me »
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline redo1973
« Reply #104 on: November 18, 2016 - 06:22:58 PM »
Thanks.  Do you have a 1972 bumper?  And, what paint did you use for the tail panel, flat, satin or that Organsol?
