Author Topic: Compression on Factory 383  (Read 1035 times)
Offline flagcraig
« on: February 05, 2016 - 12:52:40 PM »
In 1969 what were the factory compressions for a 383 motor?
Thanks.
Offline 1 Wild R/T
Re: Compression on Factory 383
« Reply #1 on: February 05, 2016 - 01:16:17 PM »
Advertised or measured?  Advertised 10-1     http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1969/69_Charger0011.jpg
Measured typically in the  8.6-1 to 9-1 range...
With the short stroke & large chamber volume it's a challenge to build compression...
« Reply #2 on: February 05, 2016 - 03:25:27 PM »
383 l code was lower compression than the Magnum N code
 realistically all the blocks are higher deck than speced at so realistic is more as wild said lower than advertised , blueprinted using thin shim head gaskets & true volumes you can get lose to 10:1
Offline flagcraig
« Reply #3 on: February 05, 2016 - 03:36:55 PM »
Can I tell if it is a I code or N code without digging into the block?
Thanks.
« Reply #4 on: February 05, 2016 - 06:52:08 PM »
What year some L codes were cast crank .
should be stamped 383 HP if it is a magnum
Offline flagcraig
« Reply #5 on: February 06, 2016 - 11:30:34 AM »
69
Offline 1 Wild R/T
« Reply #6 on: February 06, 2016 - 11:41:15 AM »
If it still has it's original pistons & it has HP stamped on the pad then it'll be high 8's low 9's C/R wise...
