Author Topic: Motor dies, starts right back up.  (Read 3550 times)
Offline roadman5312
« on: February 05, 2016 - 01:51:13 PM »
      Rebuilt 360, mild cam, 904 automatic, factory electronic distributor. Runs good, idles smooth, good power. Ocassionally when you stop and idle it will miss alittle, then die. Put in park, hit the key and it starts right back up and runs fine.  Any idea's ?.  I checked for loose connections, etc. Everything looks good. Car is a 74 Duster.
Offline 70chall440
Re: Motor dies, starts right back up.
« Reply #1 on: February 05, 2016 - 06:30:16 PM »
Id look at the fuel system; specifically the bowl level and/or needle and seat. If the fuel level is low, it can slosh out and stave when you come to a stop and cause it to die or if the needle/seat are sticking it isn't keeping the bowl full.
Current Mopar
Past Mopars
« Reply #2 on: February 05, 2016 - 07:02:49 PM »
Vacuum leak , maybe int the brake booster , or power valve too close to idle in gear , or fuel level
Offline roadman5312
« Reply #3 on: February 06, 2016 - 07:55:35 AM »
                               In an attempt to cure the problem he purchased a new Edelbrock carb, which had no affect on the problem.  :dunno:
Offline roadman5312
« Reply #4 on: February 06, 2016 - 07:59:46 AM »
                    New Edelbrock carb, no power valve.  It's also a manual brakes car.  The b!tch of this problem is you never know when it's going to happen, and it starts right back up perfectly.    :swear:   I'm leaning toward electrical , maybe pickup in the distributor.   :dunno:
« Reply #5 on: February 06, 2016 - 08:48:22 AM »
reluctor gap
Offline dougs bs23
« Reply #6 on: February 06, 2016 - 09:00:49 AM »
or maybe the coil starting to go bad??  reluctor gap set at .08?
Offline roadman5312
« Reply #7 on: February 06, 2016 - 09:16:41 AM »
                   I thought about coil, I'm going to replace it first. Reluctor gap is good.
Offline 70chall440
« Reply #8 on: February 07, 2016 - 12:14:21 AM »
I once had a coil that would heat soak and act like this, that why I try and mount them off the engine now.
Current Mopar
Past Mopars
« Reply #9 on: February 07, 2016 - 07:46:48 AM »
On the far out side I seem to remember someone posting about a loose wire that would short out only when stopping.
Would be easy enough to check, get up to speed & kick it into neutral & let the motor idle, if it doesn't die you would know it's has to do with the motion of stopping at least.
N on the other hand hook up a vacuum gauge you can read while driving & see what's going on there....sticky PCV possibly?
Offline 73_Cuda_4_Me
« Reply #10 on: February 07, 2016 - 08:06:56 AM »
When you say it idles good and runs smooth, is that in park? How much RPM drop is there when idling in park and putting it in drive? With mild cam, you can have a fight between mechanical advance and initial timing... In park, not enough load on engine, so RPM pulls mechanical in a bit, but under load, it falls off mechanical curve and stalls. Put it in park with no load, it starts right back up...
Also, fuel pump or filter could be going....
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
« Reply #11 on: February 07, 2016 - 09:16:26 AM »
How much OEM smog equipment is being used? (EGR, OSAC, idle solenoid?)
Is vacuum advance still being used?
I had an idle issue on the 340 after installing mild cam, and found mechanical and vacuum advance right on the edge for idling... when put auto tranny in gear, both advances would drop off and engine stalled. I disconnected vacuum advance, and set initial to best vacuum (18 initial), then had to recurve dizzy so all in at 35/36 degrees at 3,000 RPM...
R11 V6X EN2
Offline YellowThumper
  • I left the snow for this?
« Reply #12 on: February 08, 2016 - 05:19:40 PM »
I once had a problem with loose wire at the coil. Occasionally it would bounce off enough to cut the engine. As soon as you stopped it settled back and car would go again.  Took a month to finally find it by accident.  Feeling around and it fell off the rest of the way.
Offline roadman5312
« Reply #13 on: February 08, 2016 - 05:28:40 PM »
      He stopped by today, changed the coil, cap and rotor last Friday. All good so far. I wish he had changed them one at a time and tested, but oh well.. Thanks for all the help guys.   :2thumbs:   I think it was the coil.
« Reply #14 on: February 09, 2016 - 09:53:52 AM »
 :thumbsup:
R11 V6X EN2
