Author Topic: Challenger inner fender mod  (Read 3502 times)
Offline anthonywr450f
« on: February 05, 2016 - 09:56:37 PM »
Hey all
Am about to start work on my new project starting by replacing the front inner fenders and going to do some smoothing and blanking at same time of holes and bolts that won't be required :aussie: :aussie:
Like moving battery to back etc
Is there a reason why there is the open hole in corner were meets firewall were flap goes over or can this be blocked too??
Car was already half pulled apart to start with so wasn't sure if anything needed to run through here or if there is important reason other then to let stuff get in engine bay off the wheels lol?
Offline mopar jack
Re: Challenger inner fender mod
« Reply #1 on: February 05, 2016 - 10:23:26 PM »
Post some pics so we can see what you see. It sounds like your talking about the access holes for the upper control arm adjustments.
Offline 1 Wild R/T
« Reply #2 on: February 05, 2016 - 10:37:23 PM »
He won't need those once he installs the Pinto suspension....  Opps I meant Alterkation...
« Reply #3 on: February 06, 2016 - 01:16:26 AM »
yea mopar jack would say that's the one the access hole can still access from in engine bay if that hole was blocked so should be ok then?
has any 1 else blocked these before or always just left it?
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #4 on: February 06, 2016 - 02:05:17 AM »
A picture would sure get you more opinions.
« Reply #5 on: February 06, 2016 - 02:21:40 AM »
this just a pic of some ones elses of internet shows were I am talking about
Offline shawge
  • Zoiks!!
« Reply #6 on: February 06, 2016 - 12:01:35 PM »
The holes are for adjusting the UCA, a rubber flap does cover it.  Some folks here made vents for these holes.
- Jerry
Offline 73_Cuda_4_Me
« Reply #7 on: February 06, 2016 - 12:06:07 PM »
Also access to small-block starter and oil filter... with headers I would never seal mine up!
 :2cents:
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline YellowThumper
  • I left the snow for this?
« Reply #8 on: February 06, 2016 - 02:39:10 PM »
If retaining the stock style suspension I would leave it open to allow the needed access for alignment. Fabricate panels that snap or bolt in and paint them body color. Not as clean but...
If suspension mods eliminate needing this access for assembly and adjustments you can fill them.
Seems like a lot of work for relatively non visual areas. Easy to see with empty bay. Now add motor, starter, exhaust, brake setup, possible clutch, etc...
My2c
Offline roadman5312
« Reply #9 on: February 06, 2016 - 04:33:36 PM »
         We fabricated scoops (vents ) from aluminum for the front and rear openings to help remove heat. Painted body color.   :rebel:
« Reply #10 on: February 07, 2016 - 01:54:41 AM »
ok thanks every 1 might just leave for now and see still trying to work out what direction am going to go with suspension
do you have a picture of the scoops roadman would be interested to see what they look like
Offline roadman5312
« Reply #11 on: February 07, 2016 - 04:19:50 PM »
                       Page 20 about a third of the way down.  Fronts face forward for air in, rears face back to extract hot air.
« Reply #12 on: February 07, 2016 - 06:13:47 PM »
page 20 on what?
Offline roadman5312
« Reply #13 on: February 07, 2016 - 06:44:56 PM »
page 20 on what?
                                  http://www.cuda-challenger.com/cc/index.php?topic=93994.285      :drunk:    :smilielol:
« Reply #14 on: February 07, 2016 - 09:49:40 PM »
Cheers for link they look alright be interesting to know if they make a diff in temp man and nice car btw looks good in the orange what was heater/ac box u used in car didn't look like the standard 1 ?
