Author Topic: Dash Wiring Questions  (Read 847 times)
Offline challenger_73
« on: February 06, 2016 - 12:25:43 PM »
Can anyone tell me what these two connectors are for on my dash harness? I don't see them on my service manual diagram.
challenger_73
Offline FY1Cuda
Re: Dash Wiring Questions
« Reply #1 on: February 06, 2016 - 01:10:32 PM »
First one is the accessory feed where you can plug three threes into it.  The second one might be for your map light (?)
Offline JoeGrapes
« Reply #2 on: February 06, 2016 - 01:28:50 PM »
The first one is accessory feed. The second one is the feed to the lamp on the steering column that lights the ignition key. It plugs into the single yellow wire that comes out of the steering column with the two big flat plugs.
Offline blown motor
« Reply #3 on: February 06, 2016 - 05:46:48 PM »
Did all cars come with the ignition light?
« Reply #4 on: February 06, 2016 - 08:00:15 PM »
Thanks much! That helped out a lot. You guys are always here when i need you :cheers:
