Author Topic: How do you remove the cable from the emergency brake petal assembly?  (Read 653 times)
Offline marcus
I just spent the last hour searching all over Google and cannot find anything that explains how to do it. How do you detach this cable from the emergency brake petal assembly?
Offline soundcontrol
Re: How do you remove the cable from the emergency brake petal assembly?
« Reply #1 on: February 06, 2016 - 03:38:23 PM »
Isn't it just a pressfit? I just removed mine a few weeks ago, don't remember having an issue with it, but I can remember exactly how I did it either. The other end is just pressed in the hole in the crossmember though, removed that yesterday. Try to tap it a little with a hammer and see if it loosens up. I sprayed some rustremoval on the other end it it came loose with a few taps of the hammer.
/ Ken
topic=108917.new#new
Offline anlauto
« Reply #2 on: February 06, 2016 - 04:25:03 PM »
Yup...press-fit...just pry it out :2cents:
Offline marcus
« Reply #3 on: February 06, 2016 - 04:33:25 PM »
Knocked it loose with a small hammer then it wiggled out. Thanks!  :thumbsup:
