440, mild build. No spark:
This has been an issue since Sept 2015; I got so fed up with it (and my wife) that the car has sat since.
Some history: I was running a MSD 6 digital box, MSD blaster 2 coil with a MSD pro billet dizzy. Your basic MSD set up
Seemed to run OK for a couple of years, but my last drive in Sept 2015 it started cutting out. I barely made it home
In the garage, I had no spark at the plugs, but wet gas on the plugs
Next I did the MSD troubleshooting by the book. I got a strong spark at the coil lead by jumping the MSD box white wire to ground: A positive sign that both the box and coil is working So to me, that left the MSD distributor...... I ditched the distro, thinking the module was shot: A somewhat fairly common prob with MSD distros. I didnt have the $$ at the time for a new distro, so I left the car sitting until now
Just got the xtra $$$ and I just installed a new distro. A summit unit, basically a Mopar Perf knock off. The wiring is stone cold stupid simple
I am still running the MSD 6 box and blaster coil
-Still no spark at the plugs, but a very strong spark at the coil lead (as just mentioned above IAW the MSD troubleshooting guide)
-I triple checked all the wiring. All good. All grounds, connections, good to go
-Triple checked firing order
-I even tried 12v hot by bypassing the ignition switch in case there was a prob in that circuit)
-To rule out yet again the MSD box, I switched out the MSD box with the one I have on my chevy powered Toyota FJ. Still no spark at the plugs
-Yep, the distributors shaft is turing when the engine is
-Installed a new MSD coil, even though it checked out OK
Good solid 13v at the battery
This has to be a very simple prob that I'm just missing the root cause of. But at the same time it has really turned me off on the hobby over the last few months, (and my wife), considering all the time, labor and money that I have spent so far over the years, just to have this prob come up, something I cant seem to narrow down and figure out
I've left the car to just sit for 5 months now, and this continuing problem sure doesn't motivate to keep the interest going, considering I have basically replaced everything that the problem could be resulting in a no spark at the plugs
Any recommendations are appreciated
