Author Topic: oil pressure sending unit- Did I ruin it  (Read 1958 times)
Offline 74 challenge
« on: February 07, 2016 - 02:52:14 PM »
I am putting together my 360 in the challenger and swapped over my autometer oil pressure sending unit. Everything has gone well but today when I was re-installing the signal wire to the gauge I accidentally removed the whole stud instead of just the nut that holds on the wire. The stud has not come completely out but it seems that I cannot re-tighten it. Is it toast?
Can I reuse the stock unit? or will only an autometer unit work with the autometer gauge?
I think I am more annoyed that this unit only has about 75 miles on it.
1-8-4-3-6-5-7-2
Offline 734406pk
  • Andy
Re: oil pressure sending unit- Did I ruin it
« Reply #1 on: February 07, 2016 - 03:12:46 PM »
I think its ruined. The stock OEM sender is not compatible, it has a different resistance value. You will need to order one from Autometer.
Offline soundcontrol
« Reply #2 on: February 07, 2016 - 03:16:22 PM »
Open it up and see what happened, the stud either has another nut inside, or is soldered somehow, you might have twisted it so it disconnected, but there is a chance it can be fixed.
/ Ken
topic=108917.new#new
Offline 734406pk
  • Andy
« Reply #3 on: February 07, 2016 - 06:01:33 PM »
You never know. May be you can fix it. The sender housing is crimped shut so access is next to impossible. There is (was) a very small wire soldered/spot welded to the underside of the stud that pulled out. If you can get a connection to it, the sender should work.  There's nothing to lose at this point.
Offline roadman5312
« Reply #4 on: February 07, 2016 - 06:10:43 PM »
     I wouldn't trust it now, imo get a new one.  :2cents:
« Reply #5 on: February 08, 2016 - 07:27:06 AM »
I want it to look good so it's likely I will get a new one. However I will rip it apart and see what happened and try not to do it again.
Thanks guys.  :cheers:
1-8-4-3-6-5-7-2
Offline 734406pk
  • Andy
« Reply #6 on: February 08, 2016 - 06:34:26 PM »
I have done the same thing before. I have a "Don't do this again" file folder full of invoices.  :grinyes:
« Reply #7 on: February 08, 2016 - 08:11:55 PM »
Ohh I hear ya.
1-8-4-3-6-5-7-2
