Author Topic: Brake fluid on paint !!  (Read 2766 times)
Offline 69CHARGERMD
« on: February 07, 2016 - 04:20:41 PM »
Have the race car on the lift and my 69 Charger under it.  Notice some "fluid " on the hood of the charger and find my master cylinder was leaking from the race car and dripped on the hood of the Charger below.
I wiped if off. Tried cleaning it with some soap and water and when it dries I now have a nice white cloudy look to the paint. AARRGGHHHHHH
Any way to make it better ? ( other than painting the hood )
Not sure how long the brake fluid had been sitting there but I hadn't checked on the car in a few weeks.
Any thoughts.
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline roadman5312
Re: Brake fluid on paint !!
« Reply #1 on: February 07, 2016 - 04:22:42 PM »
                Only 1 thought.    :swear:   :stomp:   :pullinghair:   :banghead:   Man that sucks.
Offline 67vertman
  • Member since 9-23-2005
« Reply #2 on: February 07, 2016 - 04:42:19 PM »
What a bummer. What type of paint? single stage or base clear?  single stage is more porous than B/C so the break fluid has probably already started to break down the paint, if that is the case there will be no saving it.
brake fluid is hydroscopic, so soapy water should break it down.  clean the area very well and give it a good coat of wax.
Offline 69CHARGERMD
« Reply #3 on: February 07, 2016 - 04:44:58 PM »
Hood is actually a 6 pak fiberglass hood that was painted organisol black.
I think it's toast but will try some more soap and water.
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline 67vertman
« Reply #4 on: February 07, 2016 - 06:05:17 PM »
That may actually be a break.....if it lefts the paint, all you will have to do is repaint the hood.
However, since there is very little hardener in orangisol it will absorb very easily into paint and cause it to left.
Offline 70chall440
« Reply #5 on: February 09, 2016 - 12:25:33 AM »
what kind of fluid; Dot 3, 4, 5? If the paint isn't soft and spongy or visibly lifting you might get away with neutralizing it with soap and water (I would use dish soap with a degreaser in it). If it is solid (as in not lifting) you might just have to fog it in with a color that matches.
Current Mopar
Past Mopars
Offline mopar jack
« Reply #6 on: February 09, 2016 - 10:55:29 AM »
I would replace the race car fluid with dot 5 (silicon) it's not hard on paint. You probably need to put a blanket on the bottom car to keep any other fluids off of it.
Offline 67vertman
« Reply #7 on: February 09, 2016 - 03:33:07 PM »
I did that on mine.  It is a process to switch them out, but you don't have to worry about it getting on painted surfaces.
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
« Reply #8 on: February 09, 2016 - 04:44:11 PM »
love that your race car leaks brake fluid and we're not talking about how lucky you are to not find out after hitting a wall ahhaha.   Trying to find the light for you dude ;)
Want one?  Got one! ... finally
Offline 69CHARGERMD
« Reply #9 on: February 09, 2016 - 09:25:05 PM »
Thanks for the replies ( even wantone  :lol: )
Will keep you guys posted.
« Last Edit: February 09, 2016 - 09:27:22 PM by 69CHARGERMD »
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline 70chall440
« Reply #10 on: February 09, 2016 - 09:33:00 PM »
sounds healthy  :bigsmile:
Current Mopar
Past Mopars
