Author Topic: Brake lines  (Read 755 times)
Offline DadsCuda
Brake lines
« on: February 07, 2016 - 07:37:15 PM »
Yes I have another question about brakes. I'm converting front to disc & leaving rear as drums (on my 67 barracuda). Going with a conversion kit from Doctor diff & looking at new lines. There's the 'rear axle line selector' the 'front to rear line selector' and a 'front brake line selector'. Do I need all of those? I know I need the axle line, but is there a front line AND a front to rear line or is it a 'one or the other' situation? Or am I better off just getting it all & returning anything I end up not needing?
Thanks again for any words of wisdom.
Re: Brake lines
« Reply #1 on: February 07, 2016 - 07:55:53 PM »
you should end up with 7 lines total , 2 from the master cylinder to the proportioning valve , you may want to look at the Wilwood 5 line adjustable unit , 3 out from the proportioning valve , 1 to left front , 1 to right front & 1 to the rear , then you have the flex hose to the diff & 2 lines across the diff .
 260- 1179 is the part # for the wilwood prop valve
Offline DadsCuda
Re: Brake lines
« Reply #2 on: February 08, 2016 - 09:55:17 AM »
thank you! (i also just read the full description of the parts...that's pretty helpful. ugh)
