Author Topic: Idler arm issues  (Read 2785 times)
Offline JMB340Challenger
Idler arm issues
« on: February 09, 2016 - 11:56:28 AM »
 I recently ordered an idler arm for my 70 Challenger, a Moog piece.  The bushing end looks much different than my old one. The old one has the cup style washers where the arm fit into the K member,  this one just has the steel shaft with no washers on the ends. When installed, there is an excessive amount of play. Not up-and-down on the bolt, but as if the bushing itself was worn. It's very noticeable driving and also when I jack up the passenger wheel and move it back and forth. It's definitely the idler arm...I can see it pivoting. Has anyone else ran into this?  Any recommendations on a different company for a more factory style arm?  I apologize if this is a duplicate post, I tried to post this with pictures before and it didn't work. Thanks
1970 Challenger. 11:1 340 .030 over 2.02/1.60 Ported 915s, Harland Sharp roller rockers, Victor 340 intake, Holley 750 mech secondary DP, 232/242@ .050 .528 hyd cam, MSD 6AL, MSD mech advance distributor, full manual reverse valve body 727 3500 stall, 8 3/4 489 w/ 4.10s, Truetrac differential
Re: Idler arm issues
« Reply #1 on: February 09, 2016 - 12:58:28 PM »
not right for sure , used part returned maybe ?
Offline 73_Cuda_4_Me
« Reply #2 on: February 09, 2016 - 01:13:15 PM »
Moog K7041?
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
« Reply #3 on: February 09, 2016 - 01:36:00 PM »
Yes, K7041. Maybe I got a lemon. I guess I'll try and replace it. What throws me is, It fits properly, but the movement is certainly not right. Have you seen the style I'm referring to vs the original style I removed? It seems like the style I purchased without the built in "washers" is a bad design. But if it works for everyone else, maybe I just got a crummy one...
Offline roadman5312
« Reply #4 on: February 09, 2016 - 02:47:36 PM »
            Can you pull the bolt and add washers   :clueless:                           :rebel:
« Reply #5 on: February 09, 2016 - 02:52:41 PM »
Haha, you read my mind. I tried that.. No luck. I just ordered a replacement. Should arrive tomorrow, I'll be sure to update with my findings.
Offline YellowThumper
  • I left the snow for this?
« Reply #6 on: February 09, 2016 - 03:33:37 PM »
Update with a pic of new one prior to installation maybe a side by side of new and questionable one.
« Last Edit: February 09, 2016 - 03:58:18 PM by YellowThumper »
« Reply #7 on: February 09, 2016 - 03:44:34 PM »
Good thought, will do.
Offline Devil
  • Forward, Together Forward
    • Ryan's Cars in Barns
« Reply #8 on: February 09, 2016 - 04:19:43 PM »
This might be a good upgrade in the future to the Moog arm.... fyi.
http://firmfeel.com/e_body_mopar_idler_arm_bearing_kit_2.html
http://www.flickr.com/photos/hemipwr70/
http://carsinbarns.blogspot.com
71 Challenger R/T Clone
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
88 Caprice Classic Brougham
« Reply #9 on: February 20, 2016 - 09:38:46 PM »
Same part...same style.....same problem! Still has a .5" of movement. For some reason I can't post pictures. Either way, I put 3 washers with the same I.D. as the bolt shaft on the top, and two on the bottom which firms it up, sigh. It works, but it still isn't right. At least I can drive my car in a straight line now lol. I'm surprised no one else has experienced this. I have two K members and the fitment is identical on both, so it doesn't seem to be a bracket issue. I'm definitely buying the other style they make. Here are links to the two styles, the first is the moog I bought, and the second is the style that came off the car originally. http://m.summitracing.com/parts/mog-k7041
http://fcrcmachine.com/i-14214895-rare-parts-idler-arm-1968-1974-charger-challenger-gtx-barracuda-roadrunner-20252.html
Offline Mopar Mitch
« Reply #10 on: February 23, 2016 - 02:11:10 PM »
There could be a mis-package... but... did you consider the Firm Feel Idler Arm Ball Bearing setup?   This should take up any excess tolerance and improve the free motion of the idler arm.
Offline solarguy
« Reply #11 on: May 27, 2016 - 12:24:01 PM »
Did you install the one from Rare Parts?  I had the same problem with a Moog from a few years ago and currently use a few washers as spacers as you tried.  It works but I don't like the set up like that.
