Author Topic: alternator wiring questions  (Read 1680 times)
Offline SirChandlr
« on: June 06, 2005 - 09:56:26 AM »
I've got a 73 440 cuda so I know it's likely not stock, but I had an electrical fire and fried most the wires under the hood. I got everything back together, except my alternator isn't charging the battery and the car dies if I unplug the battery. I assume that I just didn't connect something correctly and want to check that first. The alternator is of the multi wire variety, with 2 nipples on the back, a screw on at the bottom, and as I recall there may be a 4th wire on the other side.
Which wire would be the problem with not charging, and what/where should it be connected?
Is there a wiring diagram I could refer to to double check the other under hood alternator, regulator and resistor conections?
thanks
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: alternator wiring questions
« Reply #1 on: June 06, 2005 - 10:57:43 AM »
here is a 74 cuda wiring diagram should be the same or close enuff
http://sybertek.us/web/wiring_diagrams.htm
Offline SirChandlr
« Reply #2 on: June 06, 2005 - 07:11:21 PM »
that's beautiful. Now I can hunt out all those gremlins. Thanks a ton.
