Author Topic: Corrosion  (Read 10558 times)
Offline cudabob496
Corrosion
« on: February 12, 2016 - 06:15:57 PM »
Put a new zinc anode in my water pump housing a year ago. Pulled it
out for inspection today. Still corrodes pretty bad, even though I had extra corrossion inhibitor and have the battery
disconnected most the time. I also went to a closed coolant system with expansion overflow
bottle, thinking less air in system, but still getting similar results.  At least this means the iron block or aluminum
is not corroding. These are about $20 at Summit.
« Last Edit: February 12, 2016 - 06:17:29 PM by cudabob496 »
2011 Kawasaki Z1000
Offline 1 Wild R/T
Re: Corrosion
« Reply #1 on: February 12, 2016 - 06:58:32 PM »
Much cheaper source....   http://www.boatzincs.com/engine.html
Offline cudabob496
Re: Corrosion
« Reply #2 on: February 12, 2016 - 07:46:43 PM »
Ya, looked into those a few years ago. For some reason
they were not recommended for cars.  Maybe because
they were designed for salt water.
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
Re: Corrosion
« Reply #3 on: February 12, 2016 - 07:52:46 PM »
Very good Cudabob496! I remember discussing this issue with you. You definitely have some electrolytic action going on there! The good news is the zinc has been deteriorating (sacrificial anode)saving some expensive base metals ( like cylinder heads etc.) This is what you want to see. You should be able to find a replacement Zinc anode w/o the brass plug for around $4. Let me know if you need a supplier.
« Last Edit: February 12, 2016 - 09:08:33 PM by 734406pk »
Offline cudabob496
Re: Corrosion
« Reply #4 on: February 12, 2016 - 08:58:17 PM »
Very good Cudabob496! I remember discussing this issue with you. You definitely have some electrolytic action going on there! The good new is the zinc has been deteriorating (sacrificial anode)saving some expensive base metals ( like cylinder heads etc.) This is what you want to see. You should be able to find a replacement Zinc anode w/o the brass plug for around $4. Let me know if you need a supplier.
Will do. Gonna replace this one in about a year.  I cleaned it up, and it has lost about 20% of the zinc.
Wish I had used these from the get-go!
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
Re: Corrosion
« Reply #5 on: February 12, 2016 - 09:11:15 PM »
Be sure to look for a mil-spec zinc as they are not all the same.
Offline HP_Cuda
  • Mopar or No Car!
Re: Corrosion
« Reply #6 on: February 13, 2016 - 02:07:49 AM »
Isolate the bolts on your radiator with rubber bushings.
That should help if you are getting electrical current flowing through your coolant.
Offline cudabob496
Re: Corrosion
« Reply #7 on: February 13, 2016 - 02:24:07 AM »
Can't hurt. But that big iron block that is grounded with a large strap to the frame is probably
what's really gettin me.
2011 Kawasaki Z1000
Offline 1 Wild R/T
Re: Corrosion
« Reply #8 on: February 13, 2016 - 02:33:47 AM »
Tell yourself that all you want, at the end of the day they are both zinc, they are both sacrificial anodes & they both do the same thing... Sacrificial Anodes are created from a metal alloy with a more negative electrochemical potential than the other metal it will be used to protect. And zinc fills that bill quite well....
http://chemwiki.ucdavis.edu/Core/Analytical_Chemistry/Electrochemistry/Case_Studies/Corrosion/Sacrificial_Anode
Offline cudabob496
Re: Corrosion
« Reply #9 on: February 13, 2016 - 02:45:51 AM »
I agree, zinc is zinc, but it's what other people were telling me. But I will look into it again.
2011 Kawasaki Z1000
Offline cudabob496
Re: Corrosion
« Reply #10 on: February 13, 2016 - 02:53:00 AM »
2011 Kawasaki Z1000
Offline cudabob496
Re: Corrosion
« Reply #11 on: February 13, 2016 - 02:59:09 AM »
wonder if my home water heater would benefit.
Seems to rust out every 10 years
2011 Kawasaki Z1000
Re: Corrosion
« Reply #12 on: February 13, 2016 - 09:41:30 AM »
That's what I did , went to my local West Marine boat supply and bought a few. Cheap insurance.   I installed mine in the aluminum rad, if that makes a difference?  :dunno:
Offline 1 Wild R/T
Re: Corrosion
« Reply #13 on: February 13, 2016 - 10:10:02 AM »
Anywhere you have a threaded port is fine.... And in the lower tank is ideal....
Re: Corrosion
« Reply #14 on: February 13, 2016 - 01:47:39 PM »
My rad is a cross flow and I welded a bung to act as a drain plug and use the anode as the drain plug.   :icon16:
