Author Topic: Corrosion  (Read 10572 times)
Offline cudabob496
Re: Corrosion
« Reply #15 on: February 13, 2016 - 03:18:54 PM »
My rad is a cross flow and I welded a bung to act as a drain plug and use the anode as the drain plug.   :icon16:
Genius
wonder if it makes a diff where the zinc is placed? radiator or engine block.
Its all connected by water, but the block with the big ground strap may see more
current across it?
2011 Kawasaki Z1000
Offline 1 Wild R/T
Re: Corrosion
« Reply #16 on: February 13, 2016 - 04:33:34 PM »
Bur an Aluminum radiator has more negative electrochemical potential so it's more reactive & likely needs more protection...
Re: Corrosion
« Reply #17 on: February 13, 2016 - 06:35:27 PM »
Genius
current across it?
Thanks, but it was your post/idea that prompted it.  :wave:
Offline cudabob496
Re: Corrosion
« Reply #18 on: February 13, 2016 - 06:43:13 PM »
even a broken clock is right twice a day
2011 Kawasaki Z1000
Offline cudabob496
Re: Corrosion
« Reply #19 on: February 13, 2016 - 07:51:04 PM »
I'm thinking the engine may need more, since it has 60 lbs of aluminum heads on it
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
Re: Corrosion
« Reply #20 on: February 13, 2016 - 08:00:44 PM »
Install zinc anodes into the engine both engine and radiator. Remove the periodically, check them and replace as necessary.
Offline cudabob496
Re: Corrosion
« Reply #21 on: February 14, 2016 - 01:32:56 AM »
Ya, apparently, when they crud-up/scale-up, the pure zinc is restricted from
doing the best job possible.  Think I'll just put in a brand new one.
Guess I'll go with Model E-0 at boatzincs.com.
« Last Edit: February 14, 2016 - 01:45:04 AM by cudabob496 »
2011 Kawasaki Z1000
Re: Corrosion
« Reply #22 on: February 14, 2016 - 02:47:57 AM »
So then why is it current new cars with aluminum radiators aren't having this problem?
Because the radiator is isolated from ground or positive?
Offline cudabob496
Re: Corrosion
« Reply #23 on: February 14, 2016 - 04:15:46 AM »
interesting article.  Maybe  I should use distilled water when mixing anti-freeze
Also, gives guidance to measure electrolosis potential of your coolant.
http://www.aa1car.com/library/cooling_system_electrolysis_corrosion.htm
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
Re: Corrosion
« Reply #24 on: February 14, 2016 - 01:52:01 PM »
seems to be a point of contention.
Purple Ice and some others say not to use distilled or de-ionized water as it will draw replacement ions out of the surrounding passages and increase corrosion.
Others say to use it.
Offline cudabob496
Re: Corrosion
« Reply #25 on: February 14, 2016 - 01:58:01 PM »
Yep, conflicting guidance out there
2011 Kawasaki Z1000
Offline cudabob496
Re: Corrosion
« Reply #26 on: February 14, 2016 - 06:14:44 PM »
if dont' have a bung, can you just drop a zinc anode in bottom or radiator,
assuming away from pump suction?
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
Re: Corrosion
« Reply #27 on: February 15, 2016 - 08:23:22 AM »
The zinc anode must be connected electrically to the base metal to work (we are making a battery).
Offline cudabob496
Re: Corrosion
« Reply #28 on: February 15, 2016 - 08:18:10 PM »
Ya, I assumed without the brass fitting, the zinc rod would lay on the bottom, and have decent contact?
I may throw one in there, and fish it out in a year to see how it looks. But will also install the regular
one with the brass fitting in my water pump housing.
2011 Kawasaki Z1000
Offline cudabob496
Re: Corrosion
« Reply #29 on: February 15, 2016 - 08:24:46 PM »
these are 14 psi and have a magnesium anode, which will wear quicker I think.
I need a 16 psi with zinc anode
http://www.summitracing.com/parts/sdk-c5zz8100rce
2011 Kawasaki Z1000
