Author Topic: Corrosion  (Read 10554 times)
Offline 734406pk
  • Andy
Re: Corrosion
« Reply #45 on: March 09, 2016 - 07:32:29 PM »
No drain plug? Well then it is what it is. You are obviously extremely knowledgeable and will keep an eye on this. I hope it works out for you! :2thumbs:
Offline cudabob496
Re: Corrosion
« Reply #46 on: March 09, 2016 - 07:57:25 PM »
ya, if need to drain, just siphon out with small plastic hose
2011 Kawasaki Z1000
Re: Corrosion
« Reply #47 on: September 11, 2016 - 07:04:52 PM »
Seems zinc anodes would protect a copper-brass radiator from
corrosion as well?
My previous Modine radiator ran for 20 years which was a copper/brass.
Never showed any signs of corrosion.
I sold it to a member here and it's still in operation.
Offline cudabob496
Re: Corrosion
« Reply #48 on: September 11, 2016 - 10:41:33 PM »
did you have aluminum engine components?
2011 Kawasaki Z1000
Re: Corrosion
« Reply #49 on: September 11, 2016 - 10:48:45 PM »
340 aluminum timing chain cover
Offline cudabob496
Re: Corrosion
« Reply #50 on: September 11, 2016 - 11:48:14 PM »
ya, only get corrosion if aluminum contacting coolant
2011 Kawasaki Z1000
