Author Topic: 489 case center section, 4.10 Sure Grip  (Read 972 times)
Offline Sinatra
« on: February 12, 2016 - 10:22:20 PM »
Complete 489-case center section for 8-3/4" Mopar axle.  It's got Richmond 4.10 gears on a Borg-Warner cone-type differential, all in great condition. Cone clutches are tight, differential pin and bore are in perfect condition, and it leaves twin black stripes every time. It turns smoothly, drove well, and did not leak. The yoke is for the smaller 7260 U-joint. Richmond gears use the 10-spline yokes and I do have a 7290 (large) 10-spline pinion yoke available at extra charge if you want or need it. I can even perform the yoke changeout for you if you'd like.
This was removed from a friend's '72 Barracuda last year for something more livable on the highway. Gas is cheap again, and it's only going down for the foreseeable future... time to have some fun again! Nothing boosts the fun factor like a set of deep gears!
$650 firm plus shipping.  No PayPal.  Cash if in person; US Postal money order or bank check preferred for long-distance sales; personal checks must clear prior to shipping.  Located in ZIP code 49802, packed weight ~80lbs.
:burnout:
Offline Sinatra
Re: 489 case center section, 4.10 Sure Grip
« Reply #1 on: March 05, 2016 - 10:55:47 AM »
Still available.  :naughty:
