Author Topic: Voltage Regulator  (Read 4199 times)
Offline msbaugh
Re: Voltage Regulator
« Reply #15 on: March 12, 2016 - 10:04:28 PM »
Yes you can remove the OEM regulator. There is a splice in the engine wiring harness forward of pin 23. The dark blue wire which feeds the reg and field positive is connected there. Do you have a wiring diagram? If not i can forward a PDF to you.
Thanks, but I've got one. Problem is, this is a Frankenstein car that had a hack job "restorer" lol.... That's all you can afford when you're on a budget! Just need some clarification sometimes, I enjoy the challenge though, thanks for the help.
I'm making my own harmess and getting really good at it.  I feel stupid for not using solder flux paste in the past, it makes wiring so much easier
Offline 734406pk
  • Andy
« Reply #16 on: March 13, 2016 - 10:31:29 AM »
Got ya. Your much better off making your own harness since you can use a much better grade of wire and increase the wire gauge sizes where needed. The OEM factory harness was borderline at best 40+ years ago not to mention that some of those Packard 56 connectors @ the bulkhead are drastically overloaded (ammeter circuit, headlights etc). Alt. bypass and adding headlight relays are a great idea. Don't forget a fuse link where needed. :thumbsup:
Here is a source (small qty) for Packard 56 connectors up to 10-12 gauge:
http://www.repairconnector.com/packard-56-split-tab-male-terminal-10-12-ga-wire/
« Last Edit: March 13, 2016 - 10:46:28 AM by 734406pk »
