Author Topic: Trunk floor holes, measurements. 70 Challenger  (Read 3803 times)
Offline roadman5312
« on: February 19, 2016 - 01:01:56 PM »
     Going to be preping the new trunk floor next week. Anybody have a picture with measurements for fuel filler tube, vent tube, shock access holes . And the hole for the fuel sender wire.  Thanks in advance.
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
Re: Trunk floor holes, measurements. 70 Challenger
« Reply #1 on: February 19, 2016 - 01:17:56 PM »
As much money these companies put into these panels, you would think they would either have them pre punched or have a template sold with them.
Offline anlauto
« Reply #2 on: February 19, 2016 - 02:58:14 PM »
I was going to ask whose panels you used....All the ones I've used had the holes pre-drilled :dunno:
Offline roadman5312
« Reply #3 on: February 19, 2016 - 03:03:01 PM »
                    Don't know. They were put in possibly 10 years ago. Can ya measure a car for me, ole buddy, ole pal.    :bigsmile:     :cheers:
Offline anlauto
« Reply #4 on: February 19, 2016 - 03:37:21 PM »
I have this for a Cuda...It will give you some of the information...
Offline roadman5312
« Reply #5 on: February 19, 2016 - 06:33:12 PM »
      Found this pic of an AMD pan if anybody could put some numbers on it. Doesn't show the hole for the vent tube though.
« Reply #6 on: February 19, 2016 - 07:07:48 PM »
Is that in the side drop off pieces? I can't remember?  :dunno:
Offline roadman5312
« Reply #7 on: February 19, 2016 - 07:31:51 PM »
                    Yes sir.
Offline moprr
« Reply #8 on: February 20, 2016 - 03:21:14 PM »
Do you need all the holes measured?
Offline roadman5312
« Reply #9 on: February 20, 2016 - 03:49:21 PM »
                  Thanks for the reply moprr. Biggest concern is the fuel fill opening. The rest I can figure out. Need dimensions of the oval and where it is located in relation to the right side @ trunk drop off and back side @ tail panel.  Thx in advance.   :2thumbs:
Offline anlauto
« Reply #10 on: February 20, 2016 - 04:14:08 PM »
Based on the above picture you should be able eye-ball it...size isn't that big of a deal, it gets covered and as long as you don't cut it bigger then the rubber.....I think you're over-thinking it :pullinghair: :2cents:
Offline roadman5312
« Reply #11 on: February 20, 2016 - 04:40:40 PM »
                     I'm just thinking about the angle of the dangle.   :smilielol:  i.e the angle of the fuel filler tube has to be pretty close so that the fit @ the quarter panel is flush.  And yea, I do have a tendency to overthink, stress and worry over little details. But I'm a perfectionist, it's a sickness   :pullinghair:               :rebel:
Offline anlauto
« Reply #12 on: February 20, 2016 - 04:47:47 PM »
A perfectionist would have used a better trunk floor :roflsmiley: :roflsmiley: :drunk:
Offline roadman5312
« Reply #13 on: February 20, 2016 - 05:04:30 PM »
                       I didn't install them, I inherited them. And except for holes they are verynicely installed. Never mind ya'll, I'll figure it out.    :drunk:    :rebel:
Offline moprr
« Reply #14 on: February 20, 2016 - 07:03:23 PM »
 Pm me your email and I can get you pics with a tape measure to it.  I always have issues uploading pics here.
