Author Topic: Shifter question  (Read 2443 times)
Offline plumcrazzy
Shifter question
« on: February 19, 2016 - 09:09:42 PM »
'70 Challenger R/T---440 Six-Pack---pistol grip shifted 4-speed with console. 1.  The shifter has always been a little tough to get into reverse. Not impossible, just a little harder than I think it should be. Find neutral, slap hard towards the left and shove forward. Have never had a failure to go into reverse but this just seems a little excessive. I have always heard that this is by design to prevent an accidental shift into reverse but am not sure I believe that story.  2.  On occasion, while cruising, the shifter will pop out of fourth gear. Never under hard acceleration but just under normal highway speed driving. I usually have my right hand resting on the shifter and can just pull it back into fourth and continue to enjoy the drive but surely this can be remedied.  Looking for opinions/assistance/suggestions. Thanks in advance.  :burnout:
Offline 70chall440
Re: Shifter question
« Reply #1 on: February 19, 2016 - 09:32:17 PM »
sounds like the shifter is a little worn and/or out of adjustment some, however it could be something more mechanical internal to the trans (I will let the trans guys speak to this). In reference to resting your hand on the shifter, I was always told not to do this as it applies pressure to the synchros and can cause damage.
Current Mopar
Past Mopars
Offline 73440
« Reply #2 on: February 19, 2016 - 09:37:27 PM »
« Last Edit: February 19, 2016 - 09:47:17 PM by 73440 »
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline plumcrazzy
« Reply #3 on: February 25, 2016 - 08:10:57 AM »
So, no comments regarding shifting into reverse? Normal? Not normal? Just wondering.
« Reply #4 on: February 25, 2016 - 10:18:13 AM »
I'll just say that of the many manual vehicles I have driven and having owned several that reverse seems to take extra effort.
I've found that after coming to a stop to shift into 1st gear for a second before trying for Reverse makes most easier..  :2cents:
Offline 70chall440
« Reply #5 on: February 25, 2016 - 10:47:56 AM »
My experience with them is that Reverse is normally a little tough to hit unless everything is set up really well and nothing is wore out.
Current Mopar
Past Mopars
« Reply #6 on: February 25, 2016 - 03:49:02 PM »
From my experience, this is what I know and do.   There are a couple of specific bolts with shoulders on them for line ups. They are required.  If you have a known good shifter, and know how to adjust it correctly, then have the correct clips that hold the levers to the pods and bars correctly then you also have a very small adjust play in the side plate which affects the gear shifting. It can cause reverse to go in hard or not at all, and also cause it to jump out of a forward gear. All this will happen with only about a .032 move in the plate. Usually because of a worn out internal part like a fork. But if you were to check this, while the trans was out, you would see what I mean. After playing these cars for 40 years I have learned the little irritations that make people let them go for bargain prices.
« Reply #7 on: February 25, 2016 - 08:07:30 PM »
there is a second spring inside the shifter that adds the load into reverse , if you clean out all of the hardened grease & dirt & re lube it I bet it will work smooth again
Offline plumcrazzy
« Reply #8 on: February 25, 2016 - 08:12:17 PM »
Thanks gentlemen---I do appreciate the information.  :ylsuper:
Offline dakota
« Reply #9 on: February 25, 2016 - 08:53:29 PM »
My 4 speed was hanging up going into reverse too, so I rebuilt the shift head.  The folks at Brewers Performance indicated that the replacement shim that they sell will address a flaw with the original design that impacts going into reverse.   There is some additional information here:
http://www.cuda-challenger.com/cc/index.php?topic=95985.60
« Last Edit: February 25, 2016 - 09:27:21 PM by dakota »
Offline 73440
« Reply #10 on: February 25, 2016 - 09:22:47 PM »
I did that also with my 51 Ford PU and three on the tree.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Cudakiller70
« Reply #11 on: February 25, 2016 - 09:25:40 PM »
 :popcorn:
The above is just my opinion
John Adams
Offline Moparparts
« Reply #12 on: February 26, 2016 - 02:46:26 PM »
Since you have a 70 and if it has all the correct pieces for the 4-speed trans interlock key removal system installed it may just be a matter of adjustment on the interlock crossshaft adjuster. Also with the interlock connected it will be less smooth going into reverse than one with-out because of turning the added levers and crossshaft.
