Author Topic: brake lights  (Read 1792 times)
Offline ASAHEMI
  • 1970 426 THE REAL HEMI
brake lights
« on: February 20, 2016 - 01:05:41 PM »
Hi new to posting questions. on a  1970 Cuda do the brake lights only work with ignition on or should they work all the time. thanks for any help
Offline CHL2T
  • Handle it, man!
Re: brake lights
« Reply #1 on: February 20, 2016 - 01:14:10 PM »
Brake lights and flashers work all the time, ignition on or not. Turns signals ignition on only.
Offline ASAHEMI
Re: brake lights
« Reply #2 on: February 21, 2016 - 07:49:01 AM »
Thank tou
Offline ASAHEMI
Re: brake lights
« Reply #3 on: February 21, 2016 - 07:49:32 AM »
sorry thank you
Offline ASAHEMI
Re: brake lights
« Reply #4 on: February 21, 2016 - 06:25:23 PM »
Thanks again for your  reply  CHL2T, would you have any idea why mine only work with the ignition on? I'm rewiring and restoring from drag car I have all OEM wiring, could it bad ground? I'm really confused. Dam the  race car wiring was so much easier. I'll take any ideas.
Offline AARuFAST
  • AARuFAST
Re: brake lights
« Reply #5 on: February 21, 2016 - 06:47:55 PM »
My 70 Barracuda Gran Cpe lights only work with key on..........
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline CHL2T
  • Handle it, man!
Re: brake lights
« Reply #6 on: February 22, 2016 - 03:19:23 AM »
Heck, now you've got me thinking... I'll check my 70 Challenger in the morning and see if they work without the key on and post back
Pretty sure they do but worth a check...
Offline Katfish
  • 70 Challenger
Re: brake lights
« Reply #7 on: February 22, 2016 - 05:08:40 PM »
No key needed.
Offline CHL2T
  • Handle it, man!
Re: brake lights
« Reply #8 on: February 22, 2016 - 07:38:42 PM »
Brake lights work with no key, confirmed, 70 Challenger
Do the above test, should confirm something, what that is....dunno  :rofl:
Re: brake lights
« Reply #9 on: February 23, 2016 - 07:52:11 AM »
the power is sourced right out of the fuse block through the brake light switch & Up into the column so it may be sourced from the wrong point in the fuse block not that it would really matter I doubt you will be driving the car often with the key in the off position
Offline ASAHEMI
Re: brake lights
« Reply #10 on: February 24, 2016 - 09:00:31 AM »
Thanks you
You guys are the best. I'm sure there will be more questions in the weeks to come LOL. again Thanks
