Author Topic: 73 challenger 340 not charging.  (Read 2740 times)
Offline ammo
« on: February 21, 2016 - 11:23:43 AM »
Has newer alternator and new ballast resistor and voltage regulator.  One field wire on alt shows 10 volts, other field wire shows 2 volts.  Battery output lug on alternator pegs my gauge at 30 volts. But no voltage to battery..  Any help would be appreciated....    :working:   Seems like same problem I had last year when black wire of battery lug on alternator shorted on the block...
Now following that black wire thru firewall to behind fuse box.  So far it's intact so looks like it burnt some again inside the car..  Anyone know where that wire goes after it goes thru the firewall?
« Last Edit: February 21, 2016 - 12:08:43 PM by ammo »
1973 dodge challenger
Offline 73440
Re: 73 challenger 340 not charging.
« Reply #1 on: February 21, 2016 - 01:34:50 PM »
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline ammo
« Reply #2 on: February 25, 2016 - 09:02:10 AM »
http://www.mymopar.com/downloads/1973/73ChallengerA.JPG
http://www.mymopar.com/downloads/1973/73ChallengerB.JPG
Is your wiring still stock that these schematics may help ?
Thanks for the diagrams.. Appears my ammeter took a dump, bypassed it and now I'm charging again..  Any source for an ammeter replacement? Or a way to get mine rebuilt?
« Reply #3 on: February 25, 2016 - 03:54:23 PM »
I have a 70 version if your stuck? ( standard cluster not rally)  Is your a rally dash?
Here is one on ebay?
http://www.ebay.ca/itm/1970-1971-1972-1973-1974-Dodge-Challenger-Plymouth-Barracuda-Amp-/201436024135?hash=item2ee685cd47:g:KT4AAOSwWnFWA3d5&vxp=mtr
Offline roadman5312
« Reply #4 on: February 25, 2016 - 04:39:40 PM »
                            Personally I would leave it bypassed and use a volt meter.    :2cents:
Offline 73440
« Reply #5 on: February 25, 2016 - 09:32:57 PM »
Good article about bypassing the amp gauge.
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 734406pk
  • Andy
« Reply #6 on: February 26, 2016 - 12:39:14 AM »
 :iagree: forget the ammeter and do the bypass. use a volt meter instead, it is much easier and safe!
