Author Topic: Sure-Fit AC System in challenger any one used these ?  (Read 2539 times)
Offline anthonywr450f
« on: February 22, 2016 - 02:20:50 AM »
hi
am currently at the point in rest were I nee to either fix current (no a/c) type fire wall all replace with ac fire wall was just wondering if any one has put a/c in challenger with no a/c fire wall if so do you have any pics and if any one has used the
Sure-Fit AC System in a no a/c type fire wall before or no of any good a/c set ups need to decide so I no which direction to head
cheers anthony :aussie: :aussie: :aussie: :aussie:
Offline ragtopdodge
Re: Sure-Fit AC System in challenger any one used these ?
« Reply #1 on: February 22, 2016 - 08:33:52 AM »
Vintage air systems retrofit.
Same with classic auto air.
Unless you need a firewall anyway since yours is rusted?
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline shawge
  • Zoiks!!
« Reply #2 on: February 22, 2016 - 12:06:26 PM »
 :iagree:  The Vintage Air and Classic Auto retrofits use the blower motor opening to pass the heating/cooling lines through to the engine bay.  No need to cut up the firewall unless you need or want to.  :2cents:
- Jerry
« Reply #3 on: February 23, 2016 - 02:22:09 AM »
can either try repair and have to do some smoothing or look at replacing
use would hap[pen to have a pic of either installed?
do they look similar in engine bay or is one bit tidier then the other?
Offline ragtopdodge
« Reply #4 on: February 23, 2016 - 02:33:47 AM »
Google is your friend.
Classic AA:
VintageAir:
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #5 on: February 25, 2016 - 12:32:21 AM »
thanks for photos
looks like all goes through the bigger hole not smaller holes for the non ac and ac style firewalls is bit to untidy for me still tho been researching the pump relocations kits and stuff so might be able to make work and all neat and tidy
cheers
« Reply #6 on: February 26, 2016 - 02:54:59 AM »
do you still need this hole (non a/c model only) for either of the aftermarket systems for a non a/c firewall type car or can I blank it as will not need with these systems?
any info/help from some 1 who has fitted system would be appreciated
cheers
Offline shawge
  • Zoiks!!
« Reply #7 on: February 26, 2016 - 11:19:01 AM »
Classic Auto uses that as a fresh air intake - I think Vintage does too.  The one on the passenger side is blocked off with a provided plate.
- Jerry
« Reply #8 on: February 26, 2016 - 04:48:04 PM »
Yea ok that's a pitty the passenger side square hole type is in good nick not like driver side that is in pic need to replace or fab around it
Cheers
Offline YellowThumper
  • I left the snow for this?
« Reply #9 on: February 26, 2016 - 06:17:25 PM »
If you are going for a cleaner look they make bulkheads with the 4 fittings in a straight line. You can then mount it  thru the far right of firewall that passes thru into the inner wheel well. The lines then come forward hidden from view.
