Safety Wire
Author Topic: Safety Wire  (Read 1484 times)
Btch n Blue
Safety Wire
« on: June 07, 2005 - 03:41:01 PM »
I know this was brought up when I posted the thread a while back about installing my Wilwood brakes.... where does one go about finding .0032" safety wire (or equivilant)?? I've check Napa, Lowe's and Home Depot.... with no luck! :mad: :gripe:
Any suggestions...?? I was told to check with an Army Surplus store, but I'm having my doubts about that.... :dontknow:
Offline Wrencher
  • 73 Plain Jane 318 Auto Project
Re: Safety Wire
« Reply #1 on: June 07, 2005 - 03:48:19 PM »
Safety wire is commonly used on aircraft.  Maybe check with your local airstrip to find where they order supplies from.   Or you could order on line from these guys:  http://www.flightessentials.net/index.asp?PageAction=VIEWPROD&ProdID=927
Btch n Blue
Re: Safety Wire
« Reply #2 on: June 07, 2005 - 03:53:37 PM »
Thanks wrencher! I'll check that site out when I get home as it's blocked here at work!....
Offline Autophile
  • Kowalski... and the keys to a sawed-off weekend!
Re: Safety Wire
« Reply #3 on: June 07, 2005 - 08:41:00 PM »
Try www.jegs.com and enter this part number in the search field: 720-8022G
Edit: I see that wrencher's suggested vendor is much less expensive. You should try his source first.
« Last Edit: June 07, 2005 - 08:42:53 PM by Autophile »
1971 Cuda, black/black, 419 cu. in. 3G Hemi with twin turbos (build in progress), AlterKtion, Wilwood 12.19" disks, billet Rallye wheels
Btch n Blue
Re: Safety Wire
« Reply #4 on: June 07, 2005 - 08:54:15 PM »
Thanks for the link wrencher!! Thought it'd be MUCH more expensive then that!! :thumbs: Might just have to buy stock in it!! :laughing:
Thanks for the tip as well Autophile... you're right, I'll go with the cheaper one.... :grinyes:
Offline Wrencher
Re: Safety Wire
« Reply #5 on: June 08, 2005 - 06:54:31 AM »
Yeah, it costs more because it's "high performance" safety wire.     :laughing:
Re: Safety Wire
« Reply #6 on: June 08, 2005 - 02:28:38 PM »
at .032 why not use solid core mig welding wire  :dontknow:
Offline Wrencher
Re: Safety Wire
« Reply #7 on: June 08, 2005 - 02:34:35 PM »
Might be stiffer, but other than for rusting, it should work the same.
« Last Edit: June 09, 2005 - 08:08:44 AM by wrencher »
Btch n Blue
Re: Safety Wire
« Reply #8 on: June 08, 2005 - 03:59:43 PM »
Already thought of that CP.... but welding wire is MUCH stiffer then safety wire....
Offline 74chall
  • Mopar or No Car
Re: Safety Wire
« Reply #9 on: June 08, 2005 - 05:40:08 PM »
hey LB just go to a motorcycle shop. I use to use saftey wire on my dirtbike handle bar grips so they didnt slide.  also on brake and shift leavers etc. VERY VERY common for off road. cheap too!
