Author Topic: Getting ready to swap the gas tank. What Do i need to know?  (Read 5699 times)
Offline GreenFish
« on: February 23, 2016 - 08:41:03 PM »
as the title says. I'm planning on pulling the old tank this weekend and replace it with the Tanks inc EFI tank I bought. any tips?
Thanks
Offline jimynick
Re: Getting ready to swap the gas tank. What Do i need to know?
« Reply #1 on: February 23, 2016 - 09:10:12 PM »
Other than the obvious drain it, support it, carefully unhook it, try to save the oem tank pad and fuel sending unit's oem lock ring and being ready for it to be heavier and clumsier than you thought? No.  :cheers:
« Reply #2 on: February 23, 2016 - 11:25:42 PM »
anti rattle straps help a lot.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #3 on: February 23, 2016 - 11:31:30 PM »
Its a good time to add a return line if you don't already have one.  Dave at Roseville has the sending unit.
« Reply #4 on: February 23, 2016 - 11:33:07 PM »
He said efi system. At first I was going to say non ECS then noticed his build
Offline dfrazz
« Reply #5 on: February 23, 2016 - 11:48:04 PM »
Missed that part.   :misbehaving:
Offline YellowThumper
  • I left the snow for this?
« Reply #6 on: February 24, 2016 - 12:32:59 AM »
Drain it, disposable clothes because you will still spill on yourself..., eye protection, gloves, enough gas cans, etc...
Offline dakota
« Reply #7 on: February 24, 2016 - 06:13:02 AM »
I hand pumped what I could out of the tank into an old gas can before dropping the tank just to reduce its weight.   Once I got the tank out, there was still some liquid sloshing around so that was poured into the gas can too using a funnel.   I left the gas can open outside for a couple of days when it wasn't raining to let it evaporate as this seemed to be the safest way to get rid of it.   Just like with those YouTube videos of what happens when people make the mistake of filling their lawnmower gas can with the can insulated from ground (like sitting on a bed liner) and having it ignite, you still have to be careful about static electricity when transferring the gas, even if it's old.
You're probably already considering it, but just in case: plan on replacing anything rubber around the tank including the grommets for the fill line and the vent tubes.   My metal vent lines were all corroded beyond recovery as well.   Good luck!
Offline GreenFish
« Reply #8 on: February 24, 2016 - 12:00:50 PM »
Thanks for the tips guys. Yes I'm converting from Carb to EFI. I am running the return line as well. I have the tanks inc sending unit and pump already installed.
So There are the two straps that hold up the tank. How does the fill tube connect? I assume Ill have to bolt it as well.
Offline shawge
  • Zoiks!!
« Reply #9 on: February 24, 2016 - 12:58:25 PM »
How are you running power and ground to the pump? On the outside or through the cabin?
- Jerry
Offline GreenFish
« Reply #10 on: February 24, 2016 - 07:27:01 PM »
actually have not figured that out yet. I was just planning on getting the tank swapped out. I may work that out as I go. May go though the cabin but ill see what life presents me.  :clueless:
Offline jimynick
« Reply #11 on: February 24, 2016 - 09:15:08 PM »
Don't forget there's supposed to be a ground strap from the tank to the body to allow the sender to work properly. If you hadn't already figured it out, the tank straps only hook into the body at the front and you can give them a lift and 1/4 turn to get them out. The fuel neck just pulls out of the rubber grommet. As in many things, a wee dab of Vaseline on the tube will greatly ease it's entrance to the tank- ahem.  :grinyes:
Offline crash340
« Reply #12 on: February 24, 2016 - 09:18:33 PM »
You also need to run a relay for the fuel pump
Greg
73 Cuda
Brisbane, Australia
Offline HP_Cuda
  • Mopar or No Car!
« Reply #13 on: February 24, 2016 - 09:19:30 PM »
Great thing about having an electric pump - is you can easily drain a tank.
 :2thumbs:
Offline GreenFish
« Reply #14 on: February 25, 2016 - 08:10:05 AM »
Thank you that's exactly what I was looking for. I did not know that.
