Author Topic: Recommend a Diff provider in the Edmonton or Calgary area?  (Read 1389 times)
Offline dilligaf
    • Willcraft Technologies Ltd.
« on: June 07, 2005 - 04:14:45 PM »
I am in Lloydminster AB (just east of Edmonton, Alberta)
on my 1974 'Cuda 8 - 3/4 it has 3:23 sure grip.
I would like 3:70.
2 1974 'Cuda's
1 1973 Challenger
Re: Recommend a Diff provider in the Edmonton or Calgary area?
« Reply #1 on: June 08, 2005 - 02:34:04 PM »
I worked for Lorne @ ground Zero Racecars in Calgary for a couple of years he is a great guy  & can get most diff parts needed , his # is
403 720 -3348
 I don`t know if he can get 3.7 gears from his suppliers though
Offline dilligaf
« Reply #2 on: June 08, 2005 - 04:32:03 PM »
CP,
I am at the mercy of good advice here.
I have a mild 360 w/2500 stall etc, and the 727 and 3:23 gears.
Some have said to go 3:91 gears, others 3:55, then another fellow said he used to run the 3:70 and felt that would be awesome for my Cuda.
The car will always be a mild 360, give or take a few minor mods I may make in time.
Street cruiser. the odd 300 mile trips.
dilligaf
2 1974 'Cuda's
1 1973 Challenger
Offline dilligaf
« Reply #3 on: June 09, 2005 - 01:03:36 PM »
What is the difference in the 2010 741 and 2010 742 8-3/4 ?
My red 1974 has the 742, the black 74 the 741.
I was going to send the 8-3/4 out of the black 74 to get 3:73 put in, and hoped when it was done, i could swap it into the red cuda.
dilligaf
2 1974 'Cuda's
1 1973 Challenger
Offline dilligaf
« Reply #4 on: June 09, 2005 - 02:40:59 PM »
dilligaf
Never Mind, I found it...
1-3/8" small stem pinion... (aka. '741')
1-3/4" large stem pinion... (aka. '742')...
2 1974 'Cuda's
1 1973 Challenger
« Reply #5 on: June 09, 2005 - 11:18:17 PM »
I would run with 3.55 gears , 3.91 get anoying on the highway
Offline Grancoupe
« Reply #6 on: June 20, 2005 - 07:46:40 AM »
355's are probably the most all around fun gear. I'm currently running 456's and they just closed the local drag strip so I'll be looking for a set of 355's myself.
Offline matt63
« Reply #7 on: July 02, 2005 - 08:22:23 PM »
I recommend AP Transmission in Edmonton (Peter).  He has been around along time and does all sorts of gearboxes and diffs. (did my A833.)
Matt in Edmonton
'73 Cuda 340 4 speed
Matt in Edmonton
'68 Valiant
