Author Topic: narrower rear end to move tires in  (Read 1238 times)
Offline b5blueaar
  • Mad Max Cuda
« on: June 07, 2005 - 09:41:48 PM »
I am upgrading to p295-50 tires on 10 inch rims with 4.5 inch backspace.
Although they will work by using air shocks to keep the fenders above the tire, I want to go to a narrower rear end to move the tires in at least 2 inches per side.
I know about the 1 inch offset shackles and front mount relocation kits used with a 69 b body rear to move the springs in 1 inch per side.
but I want to move the springs 2 or 3 inches per side.
does anyone have info on doing this?
are there any "kits" available or do I have to enigneer my own.
I want to get the 295's centered in the wheel wells.
I am thinking maybe move the springs in far enough to match the A body spring spacing and use a A body 8-3/4 rear end so I wont have to narrow a rear and axles.
any ideas or suggestions?
Re: narrower rear end to move tires in
« Reply #1 on: June 08, 2005 - 02:27:28 PM »
Mopar has a kit that notches into the frame rail for the front mount , this will move the springs in approx 3-4 "& by angling the springs you may be able to amtch the spring width for the A body to mimiimise the work there
 I have narrowed a lot of diffs & moved spring inward
Offline b5blueaar
  • Mad Max Cuda
« Reply #2 on: June 08, 2005 - 10:47:16 PM »
I will check out the mopar perf 3" kit. thanks
Is there any reason not to use the a body rear instead of narrowing a e body rear?
I think moving the rear of the spings would be easy compared to moving the front, so I dont think I would leave the spings angled.
« Reply #3 on: June 09, 2005 - 11:13:39 PM »
the A body housing will work fine But you will need to get axles made as there was never a A body 8 3/4 diff with 4.5" bolt circle
Offline b5blueaar
  • Mad Max Cuda
« Reply #4 on: June 10, 2005 - 11:01:08 AM »
I see,
wheres a good place to get axles made?
Or do I just have some ebody axles shortened?
« Reply #5 on: June 11, 2005 - 01:29:16 AM »
Mark Williams would be my first choice
Strange , Moser , Summers Bros all are good too
nivvy
« Reply #6 on: June 15, 2005 - 06:51:20 AM »
I ust ordered axels from strange yesterday for a bbody rear to put in my chally....call them and the will need all kinds of measurements!!!
8 Pack
