Author Topic: New In Box Quicktime RM-6071 bell housing  (Read 1154 times)
Offline cjd automotive
    • The Shop
« on: February 29, 2016 - 02:05:22 PM »
New In Box Quicktime RM-6071 bell housing.
Do you want to put a Tremec Transmission behind your small block Mopar? This Bellhousing will let you bolt a Ford TKO, T5 or TR3550 transmission to a 318 or 360 Mopar. Can be used for street, strip or circle track applications. 7.3 in deep bellhousing will clear the 130 tooth flywheel with 11 in clutch. Universal transmission bore will fit 4.85 in, 4.91 in, 4.685 in bores. Built from high grade steel, the cone is spun not stamped or rolled making this bellhousing dimensionally stable and accurate. Weighs 22 pounds. Fork bracket, block plate and Grade 8 hardware included. S.F.I. 6.1 approved.
$450 plus shipping or can be picked up at www.cjdautomotive.com
904-400-1802 Craig.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
www.STREETANDRACEPERFORMANCE.com
Jacksonville, FL 32220
904-400-1802
Offline brandonkuhn
Re: New In Box Quicktime RM-6071 bell housing
« Reply #1 on: May 23, 2016 - 11:03:56 PM »
Still available?
Offline MrForce
« Reply #2 on: May 24, 2016 - 11:28:17 AM »
Still available?
He is not a regular... You may want to call him.
    • The Shop
« Reply #3 on: August 11, 2016 - 11:08:04 AM »
Sorry, this is already sold.  Definitely call me me if I post something.
Craig Scholl
CJD Automotive, LLC
904-400-1802
