Author Topic: I need some opinions (and fast!)  (Read 1787 times)
Offline JS27N0B
  • Member since Jan 28th 2003.
Re: I need some opinions (and fast!)
« Reply #15 on: June 11, 2005 - 02:54:34 PM »
Why not send an e-mail right away??
If you want the car that is.
2013 Tige' RZR 343hp
Offline inot2old
« Reply #16 on: June 11, 2005 - 03:25:57 PM »
Well, the fender tag in the pictures does have correct codes for a 383 car, as well as the VIN having the correct BH29H7XXXXXXX.
If he switched the fender, did he switch the fender tag too?
'71 Cuda
'70 Charger project
'05 Crossfire Roadster
Offline TeeWJay426
« Reply #17 on: June 11, 2005 - 03:51:24 PM »
FYI, they did NOT stamp the VIN's on the engines in '67. You would need to verify the date code builds of the drivetrain hardware against the build date for the car, and if they are an appropriate time gap ahead of the car's build date, you should be reasonably sure that it's for real. As someone else mentioned, the first verification I would do would be to verify the VIN against the fender tag, since you can't be sure that got swapped in the sheet metal transfer. It is a fairly low production car, and there aren't many left like it, so if it the numbers check out, I would grab it!!
'66 Hemi Charger
'67 Coronet R/T ragtop
'03 Hemi Ram 2500 QC 4x4
'99 Durango
'98 Intrepid ES
Offline RusTy/SE
  • Just havin' fun
« Reply #18 on: June 12, 2005 - 04:41:04 PM »
 :iagree: Absolutely if possible
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
mopar_guy333
« Reply #19 on: June 12, 2005 - 05:05:58 PM »
so whats goin on now ?
Btch n Blue
« Reply #20 on: June 12, 2005 - 05:20:52 PM »
Auction is over... I'm guessing you didn't get it MoparMatt? :dontknow:
Offline Moparmatt
  • Mopar or No Car - Member Since 10/09/03
« Reply #21 on: June 13, 2005 - 02:05:18 PM »
I emailed the owner today, and as soon as I hear back, I will let you know. Hopefully, the car didn't sell, and I can check it out this weekend. (But thats probably not the case. Oh well. You win some, you lose some)
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #22 on: June 13, 2005 - 04:03:39 PM »
Well, keep us posted on the outcome!
