Author Topic: Neutral safety switch  (Read 4033 times)
Offline mojavered
  • Someday!
« on: March 02, 2016 - 02:06:18 PM »
I recently swapped out my wiring with the aaw full system.  Long process, very time consuming.  Anyway, I cannot get the starter to turn over without grounding the relay where you would plug the nss into.  My reverse lights aren't working neither. I checked for continuity to the 12v wire from plug to firewall, reverse light from plug to firewall, and ground wire from plug to relay.  All have continuity.  If I unplug ground wire from relay and ground straight from relay to ground, all good.  Is there something else I should be looking at?  Appreciate your help.
Jason
Offline FY1Cuda
Re: Neutral safety switch
« Reply #1 on: March 02, 2016 - 04:39:56 PM »
If the NSS plug comes loose from the side of the transmission, the car will not crank. Since BOTH the starter and the reverse lights don't work, it most likely has to be the plug.
Offline msbaugh
« Reply #2 on: March 02, 2016 - 05:03:13 PM »
Get underneath the car and verify that the transmission is in park or neutral first.
While you're there do what was said and make sure the NSS is in all the way.  This would cause it not to ground.
If none of that works, another possibility is the rooster comb on the valve body of the transmission does not match up with the NSS you're using on the transmission.  There were different styles if I remember correctly for 1 and 3 wire switches.
« Last Edit: March 02, 2016 - 05:04:48 PM by msbaugh »
Offline mojavered
  • Someday!
« Reply #3 on: March 02, 2016 - 08:01:42 PM »
Thanks for the replies. I ended up going down to the parts store and picking up a new nss. The center plastic piece was pretty weak in my old one and didn't protrude out as far as the new one, maybe only a few mm, but noticeable. Put the new one in, and it cranks right over.  Hopefully soon, be able to get it back on the road.
Jason
Offline msbaugh
« Reply #4 on: March 02, 2016 - 08:08:17 PM »
 :2thumbs:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: March 03, 2016 - 12:09:30 PM »
Ok who sells a NSS from a part store?, this is new to me.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #6 on: March 03, 2016 - 02:29:15 PM »
OEM 4 speed switches are pretty cheap # 4373814 Auto Standard motor # NS11
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: March 03, 2016 - 03:03:00 PM »
Dang I meant the switch setup on the pedals.
Offline mojavered
  • Someday!
« Reply #8 on: March 04, 2016 - 01:07:21 PM »
Mine is auto, the one that screws into the trans. They are about $15 at Napa.
Jason
Offline shawge
  • Zoiks!!
« Reply #9 on: March 04, 2016 - 01:18:37 PM »
HP_Cuda, if you're talking about the clutch safety switch check this thread out
http://www.cuda-challenger.com/cc/index.php?topic=111573.0
If you don't need OEM, I made a CSS from a micro switch and a home made bracket, total was about $5.
- Jerry
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: March 04, 2016 - 01:42:02 PM »
My point being is
a) they are not cheap
b) cannot be bought at a part store
If I were to do this I would want to go the OEM route.
 :bigsmile:
Offline shawge
  • Zoiks!!
« Reply #11 on: March 04, 2016 - 01:57:44 PM »
Roger that.  I would have liked an OEM one too but they are tough to find decently priced and in good condition.
- Jerry
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #12 on: March 08, 2016 - 09:19:49 AM »
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline Slotts
« Reply #13 on: March 08, 2016 - 11:20:30 AM »
David! You're killing me!  :roflsmiley:
Jim
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #14 on: March 08, 2016 - 11:54:16 AM »
 :smilielol:
LOL yeah.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
