Author Topic: parking brakes? 71 cuda  (Read 1140 times)
Offline 6771plymouth
  • john
« on: March 02, 2016 - 07:41:18 PM »
ok so I could have 2 short cables and a intermediate cable. or 1 short and 1 long cable .I don't have anything at all right now. so can I do either? is one better then the other? or how do determine witch way to go? dana 60 rear 4 speed trans if ant of this matters? thanks
Offline anlauto
Re: parking brakes? 71 cuda
« Reply #1 on: March 02, 2016 - 09:09:27 PM »
There's brackets on the inside of the frame rails. If you have one on each side you need two short cables, if you have a double bracket on the driver's side then you need one long/one short set-up...
Offline AARTA340
« Reply #2 on: March 02, 2016 - 10:50:52 PM »
Got another question for you Alan. Why the two different scenarios on the cables/brackets, one versus two? I have seen both, just never thought as to WHY?
  • john
« Reply #3 on: March 03, 2016 - 07:10:56 PM »
 :thumbsup: thanx alan
Offline anlauto
« Reply #4 on: March 03, 2016 - 07:20:24 PM »
As years went by, they looked for improvements, so maybe the two short cables work better  :dunno:
« Last Edit: March 03, 2016 - 08:49:47 PM by anlauto »
Offline plumcrazzy
« Reply #5 on: March 03, 2016 - 07:58:49 PM »
Probably two cables gives a more uniform pull.  :bigsmile:
« Reply #6 on: March 03, 2016 - 11:53:39 PM »
From what I recall, the offset to one side parking cable system was 1970.
Then in 1971, they switched to equal short length cable system.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #7 on: March 04, 2016 - 09:41:48 AM »
 :iagree:  Only one on my '70.
Offline Moparparts
« Reply #8 on: March 04, 2016 - 09:11:14 PM »
Depending on which system you use you will need to use the same parking brake pedal set up and front cable as well that correspondes. 70 pedal and front cable is different that 71 up. As mentioned 70 is one long and one short rear cable. 71 up are both short rear ones with and intermedaite cable.  Cuda and Challenger also have different length intermediate cables.
Offline larry4406
« Reply #9 on: March 05, 2016 - 07:51:54 AM »
Underside picture of my 71 Barracuda cables.  Not sure of build date.
