Author Topic: Furry window retainer makes noise when rolling window down.How do you fix furry?  (Read 1856 times)
Offline marcus
There are two of them mounted on the top of the door panel. They press against the window to prevent it from rattling. Problem is these old guys make noise when rolling the window down. The noise went away after I removed them (now the window rattles). Any one know where I get replacements or how I may be able to fix them so they do not make noise when rolling the window down?
Offline Edison1970
someone does make them.  I've seen them on ebay but are expensive.  The problem with fixing the ones you have would be what material can you get to do it with.  It appears the factory made them with a hairy fiber possibly so dirt particles can fall out and not stay in the material so they wouldn't scratch the window.
Offline lulurocks
I think you want these see below.  I don't know what year you own .. so you have to select your proper year
http://www.rtspecialties.net/proddetail.asp?prod=3581174
Offline blown motor
I think people have made their own with the loop portion of velcro. I've seen it talked about on here before. Maybe someone else will chime in.
« Last Edit: March 03, 2016 - 01:23:07 PM by blown motor »
Offline marcus
Looks like they used felt?
I'm going to try blown motors suggestion and try to rebuild it with the loop part of Velcro.
Offline marcus
Just finished the interior restoration and shared it here
JayBee was asking what I used on the window guides so I figured I would answer that on this thread
Decided I wanted a bit more padding so I went with felt/velcro combo.
The first thing I did was made note of how much coverage the old furry stuff had on the retainer so I would put the same amount back on.
The furry stuff pulled off easy. A wire wheel made quick work of the remaining glue.
Cut the felt and velcro to the correct size and got the felt wet. Gorilla glue needs water to activate
Applied gorilla glue to each end
Placed the velcro on top of the felt then stapled both sides together
Applied grazy glue gel to the retainer
Applied felt/velcro to the retainer using crazy glue gel then clamped down for about 5 min
Done!
Wash hands then repeat for the remaining retainers
Works well. No more moaning noise when I roll the window down.
Here are links to the materials I used.
3mm thick felt
http://www.amazon.com/gp/product/B016KXEYEI
Hook and loop velcro
http://www.amazon.com/gp/product/B003L1W4DQ
Gorilla Glue Minis
http://www.amazon.com/Gorilla-5000502-Glue-Minis/dp/B009M9F6JA
Loctite Ultra Gel Control Super Glue
http://www.amazon.com/Loctite-Ultra-Control-4-Gram-1363589/dp/B003Y49R7G/
