I have used one. They do not look bad but can be a pain to get on so they look decent. The one I received did not have a cut out for the VIN tag, underneath the pad there was an area that looked like it was for the VIN area so I cut it out, lo and behold it was not in the right spot. I called the vendor and they said that they had outsourced them and this was the first time they heard that the IN area was not cut out. So, if you get one and it doesn't have the VIN area cut out, measure many times.. I have seen some that had the VIN area cut out by the manufacturer and they look far better. The pad is depressed around the VIN area so it rolls down to the VIN and looks like it should be there. You will want to use a lot of silicon, tape, weights, etc. One of the Mopar mags did an article on doing it and theirs turned out well. Looks a lot better than a cracked up pad.
