Author Topic: Stupid question re 70 Cuda steering column - manual steering  (Read 4848 times)
Offline JayBee
Re: Stupid question re 70 Cuda steering column - manual steering
« Reply #15 on: June 26, 2017 - 05:25:57 PM »
Here's a picture from my Service Manual
I'm sure it would be easy enough to drill a hole and put in a corresponding size split pin.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline walkAbout
« Reply #16 on: June 27, 2017 - 03:43:41 PM »
Thanks John, have that pic/service manual too.
Sure I can drill that hole, but the dowel pin "only" prevents slipping out the shaft, when I dismount the housings under the steering wheel. But to be correct/original I would drill the hole.
Any idea where and what diameter? Otherwise I have to wait for the next meet to get that from an other Challenger, if they are original.
TIA
walkAbout
Offline JayBee
« Reply #17 on: June 28, 2017 - 08:46:32 AM »
Sorry, no I don't.
Sick right now, when I fell better I'll go in the garage and see if there's enough sticking up that I can measure.
John
2014 Toyota Avalon
Offline walkAbout
« Reply #18 on: June 29, 2017 - 02:45:12 PM »
That would be great, I appreciate it. Till then all the best for you, make a quick recovery. Still everything disassembled, once reassembled (to drive to a meet) I won't take it apart again. Still have to fix some ground in the crush can...
CU
walkAbout
Offline JayBee
« Reply #19 on: June 29, 2017 - 04:28:06 PM »
Hahaha, mine either fell in or fell out. Anyway it looks to be a 1/8 hole, a 1/8 pin punch fit right in.  It was hard to get an accurate distance from the cover end so I measured from the gearbox end and came up with 2 13/16 inches to the center. Sorry, no picture for that one.
« Last Edit: June 29, 2017 - 04:30:51 PM by JayBee »
John
2014 Toyota Avalon
Offline walkAbout
« Reply #20 on: July 04, 2017 - 04:39:14 PM »
Thanks JayBee, so it is not a strong pin. Your attachments are 404. Is it such a spring dowel pin?
OK, self answered, you can see it here:
The length is almost the same like the shoe pin it seems. Let's see...
CU
walkAbout
Offline JayBee
« Reply #21 on: July 05, 2017 - 08:34:09 AM »
Hmmm, I can see my attachments/pictures just fine. They're NOT posted with Photobucket either. I can't remember if my original (lost) pin was solid or the "spring" type., I'm thinking it was solid because I don't recall seeing the hole down the center like spring types.
John
2014 Toyota Avalon
