Author Topic: Who Knows Cragars  (Read 855 times)
Offline flagcraig
Who Knows Cragars
« on: March 07, 2016 - 01:33:36 PM »
Does anyone know the item or part # for these Cragars?  Couple designs I looked up are close but I want to be sure.
I believe the center cap is an option.
Thanks.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Who Knows Cragars
« Reply #1 on: March 07, 2016 - 02:55:54 PM »
I have classic 15" Cragar S/S on my '68 Charger - http://www.cragarwheel.com/products16-6/CragarSeries61CChromeSSSuperSportDirectDrill.  Most are unibolt (fit Mopar, Chevy, Ford) that are a PITA to put on/off since you have to line up a washer. You special order direct bolt (5x4.5) from Summit and others, as well as custom backspacing.  Double check that the center cap is included.  Cragar is offering a special 50th anniversary center cap this year - http://www.cragarwheel.com/articles1-14/LimitedEditionCragarSSCommemorativeCapNowonSale.
Offline flagcraig
« Reply #2 on: March 07, 2016 - 03:17:53 PM »
I'm looking for 15x8 rears with 4.5 backspacing and Summit/Jegs only shows 4.25 backspacing.
Will this give me more room between tire and leaf spring?  It looks like I can get direct bolt (5x4.5).
Can they do 4.5 backspacing for this wheel if I call?  As you said "Custom".
Thanks.
Offline dfrazz
« Reply #3 on: March 07, 2016 - 03:32:05 PM »
Thanks.
The 4.5" backspace increase will move the wheel out away from the springs and towards the fender.  Anything not offered would be custom order, but it is usually only $40ish per wheel although I have never ordered wheels from Jegs.  You can always add a spacer to move the wheel out too.
« Last Edit: March 07, 2016 - 03:37:11 PM by dfrazz »
