Author Topic: On to the next project - steering pump rebuild  (Read 5618 times)
Offline CUDA JAS
  • vroooooom!
« on: March 09, 2016 - 07:51:46 PM »
Well, now my box is done, on to the pump..it was leaking.
So any tips on getting the reservoir off the pump...this sucker is really on there.
I have tapped it quite a bit and it does not seem to want to move.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline dakota
Re: On to the next project - steering pump rebuild
« Reply #1 on: March 09, 2016 - 09:24:35 PM »
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: March 09, 2016 - 09:48:03 PM »
Some references if you're interested:
http://www.cuda-challenger.com/cc/index.php?topic=111260.msg1096790#msg1096790
Thanks man.  Any tips on getting the reservoir off??
Jason
74 'cuda 360/727
Offline 73440
« Reply #3 on: March 09, 2016 - 10:01:59 PM »
Jason
What FSM says is remove the two mounting studs and the pressure hose fitting , then tap filler tube with plastic hammer to remove the resorvoir. Maybe the mounting studs thread into the housing assembly.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline dakota
« Reply #4 on: March 09, 2016 - 10:45:44 PM »
Jason
Go to the 2:00 minute mark on this YouTube video:
https://m.youtube.com/watch?v=c5RaNn-fkQo
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: March 11, 2016 - 09:59:25 AM »
Thank you sir...that is pretty slick...it did not work for me...but it's pretty slick.
I currently have mine sitting in some vinegar hoping it will loosen some of the rust that seems to be holding it together.
Jason
74 'cuda 360/727
Offline 70chall440
« Reply #6 on: March 11, 2016 - 01:32:57 PM »
I have always intended to get a PS pulley puller but never have; back on my list  :bigsmile:
Current Mopar
Past Mopars
Offline CUDA JAS
  • vroooooom!
« Reply #7 on: March 11, 2016 - 02:16:58 PM »
I had no trouble with eh pully...it comes out just fine.
I can not get the pump body out of the reservoir!!
Jason
74 'cuda 360/727
Offline 70chall440
« Reply #8 on: March 11, 2016 - 02:27:06 PM »
what puller did you use?
I have used the same technique as shown in the video several times with success. Also have tried tapping around the outer edge first to try and break it free.
Current Mopar
Past Mopars
Offline anlauto
« Reply #9 on: March 11, 2016 - 02:41:01 PM »
Hit it with a hammer !
Offline CUDA JAS
  • vroooooom!
« Reply #10 on: March 11, 2016 - 02:58:19 PM »
OH I HAVE!!!
If and when I do get it off, I will have to straighten the edge of the reservoir.
No puller.  Mine has the pulley with a nut...no not me...the other kind of nut.
Jason
74 'cuda 360/727
Offline anlauto
« Reply #11 on: March 11, 2016 - 03:04:45 PM »
Hit it with a bigger hammer.....
Plug all the holes but one, and hit it with air pressure... :dunno:
Offline YellowThumper
  • I left the snow for this?
« Reply #12 on: March 11, 2016 - 06:06:57 PM »
VERY BRIEFLY. and wear disposibles...
 :grinyes:
Offline CUDA JAS
  • vroooooom!
« Reply #13 on: March 12, 2016 - 07:28:37 AM »
Man was that sucker in there!!!
BFH did the trick.
I used the jaws of my vice to support the reservoir on both sides which allowed me to pound a little harder...I needed to.  Bit of a pucker factor!!
Bent the lip a little...
I taped it all back so it looks better.
There is a little bit of rust under the o-ring of the pump body.
little in the lip of the reservoir too.
I have the reservoir sitting in a bit of vinegar to get rid of the rust.
The pump, I will just it with a wire wheel.
here are the guts.
Next week a little prep for paint a reassembly...I hope, work is getting busy.
Jason
74 'cuda 360/727
Offline anlauto
« Reply #14 on: March 12, 2016 - 08:34:33 AM »
All those blades have to go back it a certain way :2cents:
