Author Topic: On to the next project - steering pump rebuild  (Read 5621 times)
Offline CUDA JAS
  • vroooooom!
Re: On to the next project - steering pump rebuild
« Reply #15 on: March 12, 2016 - 11:17:32 AM »
All those blades have to go back it a certain way :2cents:
Gee thanks captain obvious!
They all fell out when I pulled it apart.  There are a few standing up there and show radius edge out, so that is they way there are going back in.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline gleasmja
« Reply #16 on: March 12, 2016 - 05:08:57 PM »
Not to hard of a project. After the box rebuild this will be a breeze.  Did mine all ready.
Sent from my Nexus 5X using Tapatalk
Offline anlauto
« Reply #17 on: March 12, 2016 - 05:50:27 PM »
Offline Brillo1974
« Reply #18 on: March 13, 2016 - 11:39:40 AM »
 :roflsmiley:
Trump.... The Voice of the AMERICAN People!
Offline CUDA JAS
  • vroooooom!
« Reply #19 on: March 15, 2016 - 09:56:15 PM »
OK so here is what I've found...
if you look at the pressure port in the bottom right of the reservoir:
Another angle:
Close up...on the left side now:
sure looks like a crack on the resivour...do you think?
here is the back side:
I am not convinces that it is a crack...but man I am not sure.
What you think????
I just don't want to put everything back together and have it leak at that spot.  :swear:
Jason
74 'cuda 360/727
Offline Cuda_451
« Reply #20 on: March 16, 2016 - 08:17:44 AM »
What rebuild kit are you using?
1970 Plymouth Barracuda
1995 Dodge RAM 1500 SLT
2006 Ford Mustang V6 Supercharged
Offline YellowThumper
  • I left the snow for this?
« Reply #21 on: March 16, 2016 - 02:16:16 PM »
Real hard to tell from the puter but if you look closely at pic #3 you posted. On opposite side of hole from the "crack" there is a similar marking. It is possible that it is a tooling mark from the stamping. Or... what size is the internal fitting shoulder? Could be from it if there is a nut corner and it spun past the raised area cutting into it slightly.
Couple of thoughts for ya.
Offline CUDA JAS
  • vroooooom!
« Reply #22 on: March 17, 2016 - 11:59:41 AM »
Gates....purchased at Rock Auto for peanuts.
74 'cuda 360/727
Offline CUDA JAS
  • vroooooom!
« Reply #23 on: March 17, 2016 - 12:04:56 PM »
Agreed, might  just be a stamping mark.
There does not seem to be any break in the metal, that is if I scrape away with an awl, it does not go through. It does not seem to leak with fluid siting in it.  I am just concerned that it will leak once there is pressure in the pump.  Which would suck!
I may see if I can find a reservoir of a later model truck at the wreckers this week and switch them, just to be safe.
Jason
74 'cuda 360/727
« Reply #24 on: March 17, 2016 - 05:07:35 PM »
Upside is reservoir does not hold any of the pressure. Just a container.
Do you have or have access to a tig welder? Could clean it real well and put a little heat on it. If there is a crack it will show immediately by the contamination within crack. No Crack and nothing but small puddle.
Good luck.
Offline CUDA JAS
  • vroooooom!
« Reply #25 on: March 18, 2016 - 04:35:15 PM »
Good luck.
Yeah good point...so I might be ok.
Nope no welder or I would have welded it up already. :bigsmile:
I think I will clean it up a bit more and see if it looks any worse.  I guess I could always put a little JB weld on the outside just to be safe.
Jason
74 'cuda 360/727
Offline jimynick
« Reply #26 on: March 18, 2016 - 11:40:15 PM »
Jas, try a little bit of lacquer thinner in it to see if it wicks through to the other side. Push come to shove, bring it over and son Jim, who works as a non destructive technician can either mag or dye check it. Personally, I'd clean it with brake cleaner and flux it and put a wee dab of solder on it. Then you don't need to worry anymore. Just my  :2cents:
Offline CUDA JAS
  • vroooooom!
« Reply #27 on: March 22, 2016 - 10:15:17 PM »
Thanks Ian
I had some mineral spirits sitting on it for  few days, and it was dry on the inside, so I think it will be ok.
I went ahead and started reassembly tonight.
Jason
74 'cuda 360/727
