Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
No spark.
« previous
next »
Print
Pages: [
1
2
3
Author
Topic: No spark. (Read 2961 times)
Cuda_451
Jr. Member
No spark.
on:
March 11, 2016 - 04:50:07 PM »
Okay so I have a 70 Barracuda with a 400 that is having major electrical issues. I have a new distributor and wires bought from Mancini Racing and am getting no spark from the plug wires. Also, am having problems with exterior lighting. Thanks!
Logged
1970 Plymouth Barracuda
1995 Dodge RAM 1500 SLT
2006 Ford Mustang V6 Supercharged
dfrazz
1970 Cuda - 1968 Charger
Resident
Re: No spark.
Reply #1 on:
March 11, 2016 - 06:55:02 PM »
Does it turn over at all? Starter? Coil? Battery? Need more info....
Logged
roadman5312
Sr. Resident
Re: No spark.
Reply #2 on:
March 11, 2016 - 07:08:37 PM »
Quote from: dfrazz on March 11, 2016 - 06:55:02 PM
much more info needed.
Logged
Cuda_451
Jr. Member
Re: No spark.
Reply #3 on:
March 11, 2016 - 07:57:17 PM »
Turns over plenty quick, battery is running off of a charger right now. What else is needed?
Logged
Cuda_451
Jr. Member
Re: No spark.
Reply #4 on:
March 11, 2016 - 08:01:38 PM »
Coil is a new accel coil, starter is older
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Re: No spark.
Reply #5 on:
March 11, 2016 - 08:04:53 PM »
check all your grounds & cable connections to battery etc,,, sounds like it may be cranking OK?
could be any of many weak spots..read this one
http://www.cuda-challenger.com/cc/index.php?topic=108059.msg1062562#msg1062562
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
dougs bs23
Sr. Member
Re: No spark.
Reply #6 on:
March 11, 2016 - 09:29:35 PM »
dizzy in correctly? reluctor gap set to right gap?
Logged
see Bill run go Navy football///fly navy
Cuda_451
Jr. Member
Re: No spark.
Reply #7 on:
March 11, 2016 - 11:28:04 PM »
Everything is set right, it's also a new wiring harness for the engine, could a weak battery prevent a spark from getting to the plugs?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: No spark.
Reply #8 on:
March 12, 2016 - 06:14:41 AM »
Are you getting consistant spark from the coil , reluctor gap should be .008 , what kind of ECU are you using ?
Logged
Cuda_451
Jr. Member
Re: No spark.
Reply #9 on:
March 12, 2016 - 06:31:59 AM »
It's a Mopar Performance ECU for up to 8,000 rpms, and the spark varies, sometimes it's a consistent blue spark from the coil and others it will be off and on. But no spark at all from plug wires.
Logged
Cuda_451
Jr. Member
Re: No spark.
Reply #10 on:
March 12, 2016 - 03:04:44 PM »
Logged
Cuda_451
Jr. Member
Re: No spark.
Reply #11 on:
March 15, 2016 - 10:50:25 PM »
Logged
dougs bs23
Sr. Member
Re: No spark.
Reply #12 on:
March 16, 2016 - 10:19:11 AM »
Could be a bad ecu. Even if it's new that doesn't always mean it will work but really sounds like some type of grounding issue
Logged
Cuda_451
Jr. Member
Re: No spark.
Reply #13 on:
March 16, 2016 - 01:09:27 PM »
I've swapped ECU's and got a constant spark, but still no spark from plug wires
Logged
dougs bs23
Sr. Member
Re: No spark.
Reply #14 on:
March 16, 2016 - 03:15:34 PM »
new cap and rotor? recheck the reluctor gap
Logged
Print
Pages: [
1
2
3
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
No spark.
